Results 1 to 8 of 8
    Newbie level 6
    Points: 147, Level: 1
    Jun 2017
    11
    147
    SD card using FAT file and File i/o libraries
    I am interfacing SD card on ARM: LPC3250, I am able to read write single sector.Now i am trying FAT16 with 2GB card.
    PROBLEM: I googled, getting FAT library without application I/o (I mean without File operation File_open, File_read etc..) libraries. I tried few FAT16 library it is pointing to dummy file operation definition or through SPI(I am not using SPI).
    Please suggest any links to FAT with file operation libraries/ open source code.
    Thanks,
    •   Alt13th September 2017, 14:46
      advertising
    Points: 8,160, Level: 21
    Easyrider83's Avatar
    Oct 2011
    Tallinn, Estonia
    1,463
    8,160
    21
    Re: SD card using FAT file and File i/o libraries
    Love me or hate me. All infractions will be ignored.
    •   Alt13th September 2017, 15:22
      advertising
    Points: 113, Level: 1
    Jul 2017
    113
    Chan's FatFs library is definitely the best option.
    •   Alt15th September 2017, 20:27
      advertising
    Newbie level 6
    Jun 2017
    11
    147
    Files in SD card getting deleted after write single block
    Hello All,
    I am interfacing SD card on ARM: LPC3250, I am able to read write single sector.Now i am trying FAT16 with 2GB card using Chan's FatFs library.
    I read 512 bytes from Doc1.txt and trying to overwrite 512 bytes of Doc2.txt.
    Problem is after writing i am facing below issue:
    1) Some times file in SD card deleted.
    2) It asking for SD card format.
    3) Not responding to command deselect or put card to to Idle.
    When i open SD card in hexa editor data is written but root directory size of file is not updated and MBR is replaced by BOOT Sector.
    Code snippet below and attached the files i am working. Please suggest what am i missing .
    void c_entry(void)
    	/* Read Doc1.txt */
    	str_copy(&pFileName,"Doc1.txt");
    	f_mount (fs, "", 0);
    	retres = f_open(&filp,pFileName, FA_READ);
    	if(retres == FR_OK)
    		f_read(&filp,pbuff,512,&bytesread);
    	/* write Doc2.txt */
    	str_copy(&pFileName,"Doc2.txt");
    	bytesread = 0;
    	retres = f_open(&filpw,pFileName, (FA_READ | FA_WRITE));
    	if(retres == FR_OK)
    		f_write(&filpw,pbuff,512,&bytesread);
    	retres = f_close(&filp);
    	retres = f_close(&filpw);
    	/* Deselect card */
    	sdmmc_cmd_send(SDMMC_SELECT_CARD, 0, &resp);
    	/* Place card into idle to shut it down */
    	sdmmc_cmd_send(SDMMC_IDLE, 0, &resp);
    	sdmmc_close();
    	/* Enable SDMMC power */
    	phy3250_sdpower_enable(FALSE);
    	/* Disable interrupts in ARM core */
    	disable_irq_fiq();
    Last edited by FvM; 30th October 2017 at 08:34. Reason: Merged with previous SD-Card thread
    Newbie level 6
    Jun 2017
    11
    147
    Read and write from SD card using DMA Controller
    I have interfaced SD-CARD with ARM-LPC Raw read and write working well with FAT. Now I want introduce DMA for read and write to avoid CPU.
    Please suggest how to read and write from SD card using DMA Controller.
    Newbie level 6
    Jun 2017
    11
    147
    DMA Sequence to Read SD card
    Reading and writing SD card using DMA requires bus interface like SPI?
    I want to read and write SD card using DMA without SPI is it possible?
    I tried to read first sector of from SD card through DMA channel 0 but not succeed. I enabled channel 0 trying to read first sector of SD card(Sector Zero).
    Source address i mentioned Zero am i correct ?
    dma_src = 0x0;
    dma_dest= (UNS_32)databuff;
    next_lli = 0x0;
    next_ctrl= 0x0;
    config_ch = 0x1;
    Please suggest/help.
    The sequence of read and write from SD card using DMA Controller(I am using ARM LPC)
    •   Alt24th November 2017, 06:54
      advertising
  7. #7
    Points: 239,566, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,508
    239,566
    100
    SD card can be interfaced either through dedicated SD card interface (fast access with 4 data lines) or SPI interface.
    In any case, the used interface has to be set up respectively. It's not clear which interface should be addressed by your code snippet.
  8. #8
    Newbie level 6
    Jun 2017
    11
    147
    I am trying SD card using DMA interface.
