Results 1 to 3 of 3
    Full Member level 2
    Points: 772, Level: 6
    Sep 2016
    133
    772
    Is series resistor to IC is required.
Name:	power supply pins.png
    Friend please refer the image.
    In this circuit I added an series resistor to the controller across VDD and MCLR pins...
    Is this good practice or their is no need to put an series resistor across VDD and MCLR..?
    •   Alt13th September 2017, 11:41
      advertising
    Points: 47,675, Level: 53
    Most Frequent Poster
    Apr 2014
    9,747
    47,675
    53
    Re: Is series resistor to IC is required.
    the second time you show a schematic with a series resistor in VCC or VDD line. Why?
    As before: It still is no good idea.
    An electrolytic capacitor is not suitable to stabilize VDD.
    If you want a delayed MCLR, then your circuit simply is wrong.
    Just reading the datasheet will give you the answer to both VDD and MCLR questions.
    •   Alt13th September 2017, 11:52
      advertising
    Member level 3
    Points: 562, Level: 5
    Relayer's Avatar
    Jul 2016
    Werribee, Australia
    55
    562
    Hello venkates2218,
    I have to agree with KlausST 100%.
    C11 should be a non-polarized cap of 0.1uF placed as close to the IC itself when producing
    the PCB pattern.
    R2 should not be in-circuit at all, as with C10 and R1, as the MCLR needs +5V to operate
    correctly.
    Regards,
    Relayer
