Results 1 to 6 of 6
    Points: 93, Level: 1
    May 2017
    93
    S11 for practical antennas
    What value of S11 is required for practical antennas . Is it less than -10dB or -6dB ?
    •   Alt13th September 2017, 10:39
      advertising
    Full Member level 5
    Points: 1,858, Level: 10
    Aug 2015
    Coral Springs, Florida
    272
    1,858
    10
    Re: S11 for practical antennas
    Don't depend on S11 as much as the antenna gain. If you have the gain you want, then S11 really doesn't matter all that much. That said, try to keep your VSWR under 3:1. Narrow band antennas are fairly easy to get the performance you want, wider band antennas need a lot of "wiggle room".
    •   Alt13th September 2017, 16:05
      advertising
    Newbie level 1
    Points: 14, Level: 1
    Sep 2017
    14
    This cavity-backed slot antenna has a first resonance at about 2.45 GHz. At this frequency, the cavity backed slot antenna is roughly 0.474 wavelengths long - which is roughly the length of a resonant dipole antenna. S11 drops to below -20 dB at this frequency, indicating that most of the power is radiated away. The bandwidth, measured (somewhat arbitrarily) as the frequency span that S11 is less than -6 dB is roughly from 2.35 GHz to 2.55 GHz, giving a fractional bandwidth of slightly over 8%.
    Hope it helps :)
    •   Alt14th September 2017, 06:55
      advertising
    May 2017
    93
    Thanks for the reply .
    Any tips on improving the gain (Currently I am working on an Inverted F PCB antenna and a gain of about 4.3dBi). Also any points to consider while designing a dual band antenna considering that we require high bandwidths for the two resonance frequencies.
    Points: 233,721, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    40,376
    233,721
    100
    The previous post is a quote from the internet tutorial http://www.antenna-theory.com/antenn...ture/slot2.php which doesn't actually answer your question. I suggest to ignore it.
    •   Alt14th September 2017, 08:56
      advertising
    Advanced Member level 2
    Points: 5,989, Level: 18
    Jan 2007
    Sweden
    598
    5,989
    18
    VSWR at TX is a bit as efficiency for car engines. If you have a lot of fuel and an engine that is uncritical in its function, you will get needed result at cost of the fuel (with an less good VSWR).
    It is mainly for small battery powered transmitters best efficiency are of importance, but also some very powerful transmitters need to keep losses extremely low as they else not can keep temperature within safe range for the electronic circuit.
    VSWR at RX is a similar situation which effects signal/noise ratio. Is every dB counted to be able to receive a signal, must VSWR be low.
    High VSWR due to poor matching at antenna will result in that for example outside of a coaxial braid will be a part of the antenna. Can increase problem with near-field noise or reduce effective overall gain.
    VSWR is a ratio and often expressed as a such.
    Expressed as dB is it usually called "return loss" which is a positive value. Negative loss is an amplification.
