Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
    Newbie level 6
    Points: 89, Level: 1
    Sep 2017
    13
    89
    AC DC full bridge power supply
    hello guys,
    im designing a variable output full bridge power supply and i found an intresting design from microchip but its DC DC, so could you please help me to have AC input 230V and DC and 30V 5A as maximum output, what should i add ?..
    Points: 55,084, Level: 57
    Apr 2014
    11,146
    55,084
    57
    Re: AC DC full bridge power supply
    In simplest case:
    Transformer --> bridge rectifier --> bulk capacitor.
    Countless internet resources show you how to. Even in this forum you may find enough informatins.
    Full Member level 6
    Points: 2,698, Level: 12
    Sep 2013
    322
    2,698
    12
    230V AC connect to common mode chock (1A) then MOV then capacitor for filter then bridge rectifier followed by bulk electrolytic capacitor
    then connect to DC DC converter
    For IC powering find below link
    http://www.datasheetdir.com/Offline-...lication-Notes
    Newbie level 6
    Sep 2017
    13
    89
    thank you, for reply i just wonder if there is a way to have AC DC without transformer to have 80v 2A then connect to DC DC converter
    •   Alt13th September 2017, 12:41
      advertising
    Apr 2014
    11,146
    55,084
    57
    I doubt it . The cheapest (without isolation) maybe is an autotransformer.
    Full Member level 6
    Sep 2013
    322
    2,698
    12
    Separate isolation transformer not required because your DC DC converter having isolation transformer
    If you see all offline AC to DC converter do not have separate isolation transformer
  7. #7
    Newbie level 6
    Sep 2017
    13
    89
    thanks to all, so how can i get 80V 2A without transformer ?? because i saw many solution without transformer but they dont deliver enough current ?
    •   Alt14th September 2017, 08:03
      advertising
  8. #8
    Apr 2014
    11,146
    55,084
    57
    Isn´t it the same question as in post#4?
  9. #9
    Newbie level 6
    Sep 2017
    13
    89
    autotransformer its isolated solution !
    •   Alt14th September 2017, 10:05
      advertising
  10. #10
    Apr 2014
    11,146
    55,084
    57
    No.
  11. #11
    Full Member level 6
    Sep 2013
    322
    2,698
    12
    You can use resistor divider or better resistance capacitance divider, You can also use zener diode with series resistor
    80V @2A is very difficult from 230V Ac
    High power loss happened in resistor
  12. #12
    Newbie level 6
    Sep 2017
    13
    89
    thank you smijesh, yes in fact that what i realise, its very difficult to have 80v from 220v ac, in fact, my board is small to have a traditional transformer so im thinking to have planar transformer but im not sure that it exists from AC 220v to 90-80v DC they offen used for DC DC, what do you think?
  13. #13
    Newbie level 6
    Sep 2017
    13
    89
    i think planar transformer is not doable due to the primary winding number so i think im obliged to use a traditional transformer, whats the smallest solution that can i have ?
  14. #14
    Apr 2014
    11,146
    55,084
    57
    An autotransformer is:
    * smaller than a traditional transformer
    * is cheaper than a traditional transformer
    * is non isolating
    May I ask why you refuse to consider an autotransformer?
  15. #15
    Newbie level 6
    Sep 2017
    13
    89
    they are not a pcb mount also they have a big height
  16. #16
    Newbie level 6
    Sep 2017
    13
    89
    220V to 80V 2A transformer
    hello guys, in fact im working on a project and i have some mechanical limitations and i am staked to finding the smalest solution, so could you please help me to find the smallest transformer or solution to have these values 220V to 80V 2 A, thank you
    •   Alt20th September 2017, 14:12
      advertising
  17. #17
    Apr 2014
    11,146
    55,084
    57
    Don´t start new threads with the same topic.
    Please show us where you have this information from:
    It´s simply nonsense.
  18. #18
    Newbie level 6
    Sep 2017
    13
    89
    thank you klaus for your help, in fact it have a mechanical limitations (casing) so thats why i cannot use auto transformers they are more bigger than my case
  19. #19
    Points: 13,065, Level: 27
    schmitt trigger's Avatar
    Apr 2013
    C4E4DEEEDCE6ECD2
    2,205
    13,065
    27
    A full bridge, like the one you are showing, is fully capable of processing the raw (about 320V) DC directly from the rectified 230 VAC. You don't require stepping it down to 80VDC.
    Of course, you will require to calculate and select the correct Mosfets, passive components and most importantly, the transformer with the proper primary ratings.
    If you don't want or can't perform the necessary calculations, and simply want to copy/paste the design you have shown, then you have to use an autotransformer. There is no way around this fact.
    My batteries are recharged by "Helpful Post" ratings.
  20. #20
    Apr 2014
    11,146
    55,084
    57
    Please learn to give useful informatins.
    --> we can not know what this means: is it 1cm x 1cm x 1cm or is it 1m x 1m x 1m...
    That´s not the problem of an autotransformer.
    In your case the 160VA autotransformer is as small as an 100W standard transformer.
    They have all form options than a standard transformer: toroidal, or standard, it may be PCB mount or not, potted or not... and so on.
    If an autotransformer is too big, then every low frequency transformer will be too big.
    Review the thread to see how many other options you have to generate 80V/2A AC from 230V AC. I see none.
    I doubt that repeatedly asking the same question will bring new results. (More than 440 times this thread has been viewed)
    I doubt that repeatedly refusing facts or posting unverified statements will bring you a step ahead.
    Honestly, I gave the best (smallest) possible solution that I know.
