+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 5
    Points: 202, Level: 2
    Join Date
    Nov 2016
    Posts
    9
    Points
    202
    Level
    Throughput calculation on design in XIlinx
    How to calculate throughput, latency from a simulation of verilog design?
    •   Alt13th September 2017, 04:39
      advertising
  2. #2
    Advanced Member level 5
    Points: 35,434, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,485
    Points
    35,434
    Level
    45
    Re: Throughput calculation on design in XIlinx
    Latency is the number of clocks between inputting data and getting an output.
    Throughput is calculated by inputing a known amount of data in a specific time frame, and multipying the value in bits/s. Depending on the design, you can usually calculate a theoretical throughput from the architecture, but you may have to measure it on real hardware for real life results.
    1 members found this post helpful.
    •   Alt13th September 2017, 07:32
      advertising
  3. #3
    Newbie level 5
    Join Date
    Nov 2016
    Posts
    9
    Points
    202
    Level
    Click image for larger version.
    If this is the simulation result, what would be the latency and throughput of the design? Could you explain me. Thanks.
    •   Alt13th September 2017, 07:54
      advertising
  4. #4
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,485
    Points
    35,434
    Level
    45
    Without knowing the design, or seeing the code, I have no way of working that out from a very limit waveform.
