Results 1 to 8 of 8
    Newbie level 3
    Points: 957, Level: 7
    Aug 2012
    957
    7
    Data acquisition software (e.g. LabView, DASYLab). What should I use?
    I need to purchase data acquisition software (e.g. LabView, DASYLab) to download data on RS-422. What should I use?
    Right now I have the following components in my system:
    1. Laptop computer with USB port.
    2. Black box containing 56K bytes of data. It has an RS-422 port.
    3. USB to RS-422 converter (manufactured by Sealevel).
    4. RS-422 cable.
    I need to send commands to the black box on the RS-422. And then I need to transfer data from the black box to the computer on the RS-422 and save the data in a binary file.
    I need to design a simple user interface to do this. What is the best data acquisition software to do this with?
    A long time ago I used a package called “Test Point” by Capital Equipment Corporation. I loved that software, but apparently it is no longer sold. :( I know LabView is the most commonly used data acquisition package, but I have heard the learning curve is substantial. Will DASYLab do what I want? I have heard it is simpler than LabView. Would you recommend something else? Wonderware? Azeotech?
    Thank you
    •   Alt12th September 2017, 16:48
      advertising
    Member level 5
    Points: 563, Level: 5
    Apr 2017
    86
    563
    Re: Data acquisition software (e.g. LabView, DASYLab). What should I use?
    It seems that LabView has got much bigger community around the Internet - in case of any problems very often you can find very similar question/solution at NI forum.
    Points: 11,741, Level: 25
    Apr 2010
    1,800
    11,741
    25
    Quote Originally Posted by Buckeye_Guy View Post
    Thank you
    So the job is only to save the 56k bytes sitting in blackbox to the PC ?
    •   Alt13th September 2017, 06:48
      advertising
    Newbie level 3
    Aug 2012
    957
    7
    Quote Originally Posted by srizbf View Post
    Yes, that is correct. I send the box commands, and it streams data back in 1K chunks.
    Newbie level 5
    Points: 1,291, Level: 8
    Dec 2010
    8
    1,291
    8
    The USB to RS-422 converter will create a COM port on your computer. You may find many data loggers in Internet.
    I have used this application in the past: http://www.aggsoft.com/serial-data-logger.htm
    It can send requests to a device and log to files.
    •   Alt20th September 2017, 13:31
      advertising
    Member level 5
    Apr 2017
    86
    563
    Depending on your programming skills you could use Python with TKinter GUI extension to make a simple control panel - the software is for free.
  7. #7
    Newbie level 1
    Points: 23, Level: 1
    Nov 2017
    23
  8. #8
    Points: 2,200, Level: 10
    Sep 2006
    Loughborough---UK
    37
    2,200
    10
    There is a open source software called script communicator that can log data to text file, google search for it.
