Results 1 to 9 of 9
    Member level 4
    Points: 887, Level: 6
    May 2015
    72
    887
    Initializing a very long vector with some repetition
    I have to initialize a very long vector in the pattern such as
    x(0*64 TO 0*64+15) = '1';
    x(1*64 TO 1*64+15) = '1';
    x(2*64 TO 2*64+15) = '1';
    x(15*64 TO 15*64+15) = '1';
    What is the best way to do so? In some scenarios, it may b even bigger than this, but pattern remains similar.
    Points: 35,434, Level: 45
    Jun 2010
    6,485
    35,434
    45
    Re: Initializing a very long vector with some repetition
    Is this VHDL, as it has syntax errors?
    Where is this initialisation done? Can you post the real code, or a complete example rather than just a snippet?
    •   Alt12th September 2017, 13:34
      advertising
    Member level 4
    May 2015
    72
    887
    The vhdl code is as follows:
    Code VHDL - [expand]
    8
    9
    10
    11
    GENERIC(LLrow: INTEGER := 16);
    SIGNAL b0 : STD_LOGIC_VECTOR(N*N/4 - 1 downto 0) := (OTHERS => '0') ;
    variable row : INTEGER RANGE 1 TO N := 1;
    variable addr2_2 : INTEGER RANGE 0 TO N*N-1 := 0;
                                            if row <= LLrow then
                                                b0(addr2_2 + LLrow-1 downto addr2_2) <= (OTHERS => '1');
                                                row := row + 1;
                                                addr2_2 := addr2_2 + N/2;
                                            end if;
    As I try to synthesis this, it never comes out of running synthesis.
    Jun 2010
    6,485
    35,434
    45
    Please post the whole code, or complete example showing the problem.
    •   Alt12th September 2017, 14:04
      advertising
    Points: 7,092, Level: 20
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germay
    1,028
    7,092
    20
    Blog Entries
    row := row + 1;
    end if;
    This part gives me a headache...plz use signals!
    Stop using variables in the synthesizable part of your design. You can do everything with signals.
    .....yes, I do this for fun!
    Points: 28,163, Level: 40
    ads-ee's Avatar
    Sep 2013
    USA
    6,435
    28,163
    40
    Quote Originally Posted by dpaul View Post
    Don't you know if you write VHDL using variables it behaves more like software
  7. #7
    Member level 4
    May 2015
    72
    887
    dpaul... This part gives me a headache...plz use signals!
    I have a very long code using Finite State Machine. Here I attach the code. The code is sequential, so using signal provides output only on the next clock cycle. Also I sometimes need to update the value of an object within the same loop twice, which is not possible with signals, so I use variables.
    Please check my code design strategy and suggest me how to make my code efficient
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    194
    195
    196
    197
    198
    199
    200
    201
    202
    203
    204
    205
    206
    207
    208
    209
    210
    211
    212
    213
    214
    215
    216
    217
    218
    219
    220
    221
    222
    223
    224
    225
    226
    227
    228
    229
    230
    231
    232
    233
    234
    235
    236
    237
    238
    239
    240
    241
    242
    243
    244
    245
    246
    247
    248
    249
    250
    251
    252
    253
    254
    255
    256
    257
    258
    259
    260
    261
    262
    263
    264
    265
    266
    267
    268
    269
    270
    271
    272
    273
    274
    275
    276
    277
    278
    279
    280
    281
    282
    283
    284
    285
    286
    287
    288
    289
    290
    291
    292
    293
    294
    295
    296
    297
    298
    299
    300
    301
    302
    303
    304
    305
    306
    307
    308
    309
    310
    311
    312
    313
    314
    315
    316
    317
    318
    319
    320
    321
    322
    323
    324
    325
    326
    327
    328
    329
    330
    331
    332
    333
    334
    335
    336
    337
    338
    339
    340
    341
    342
    343
    344
    345
    346
    347
    348
    349
    350
    351
    352
    353
    354
    355
    356
    357
    358
    359
    360
    361
    362
    363
    364
    365
    366
    367
    368
    369
    370
    371
    372
    373
    374
    375
    376
    377
    378
    379
    380
    381
    382
    383
    384
    385
    386
    387
    388
    389
    390
    391
    392
    393
    394
    395
    396
    397
    398
    399
    400
    401
    402
    403
    404
    405
    406
    407
    408
    409
    410
    411
    412
    413
    414
    415
    416
    417
    418
    419
    420
    421
    422
    423
    424
    425
    426
    427
    428
    429
    430
    431
    432
    433
    434
    435
    436
    437
    438
    439
    440
    441
    442
    443
    444
    445
    446
    447
    448
    449
    450
    451
    452
    453
    454
    455
    456
    457
    458
    459
    460
    461
    462
    463
    464
    465
    466
    467
    468
    469
    470
    471
    472
    473
    474
    475
    476
    477
    478
    479
    480
    481
    482
    483
    484
    485
    486
    487
    488
    489
    490
    491
    492
    493
    494
    495
    496
    497
    498
    499
    500
    501
    502
    503
    504
    505
    506
    507
    508
    509
    510
    511
    512
    513
    514
    515
    516
    517
    518
    519
    520
    521
    522
    523
    524
    525
    526
    527
    528
    529
    530
    531
    532
    533
    534
    535
    536
    537
    538
    539
    540
    541
    542
    543
    544
    545
    546
    547
    548
    549
    550
    551
    552
    553
    554
    555
    556
    557
    558
    559
    560
    561
    562
    563
    564
    565
    566
    567
    568
    569
    570
    571
    572
    573
    574
    575
    576
    577
    578
    579
    580
    581
    582
    583
    584
    585
    586
    587
    588
    589
    590
    591
    592
    593
    594
    595
    596
    597
    598
    599
    600
    601
    602
    603
    604
    605
    606
    607
    608
    609
    610
    611
    612
    613
    614
    615
    616
    617
    618
    619
    620
    621
    622
    623
    624
    625
    626
    627
    628
    629
    630
    631
    632
    633
    634
    635
    636
    637
    638
    639
    640
    641
    642
    643
    644
    645
    646
    647
    648
    649
    650
    651
    652
    653
    654
    655
    656
    657
    658
    659
    660
    661
    662
    663
    664
    665
    666
    667
    668
    669
    670
    671
    672
    673
    674
    675
    676
    677
    678
    679
    680
    681
    682
    683
    684
    685
    686
    687
    688
    689
    690
    691
    692
    693
    694
    695
    696
    697
    698
    699
    700
    701
    702
    703
    704
    705
    706
    707
    708
    709
    710
    711
    712
    713
    714
    715
    716
    717
    718
    719
    720
    721
    722
    723
    724
    725
    726
    727
    728
    729
    730
    731
    732
    733
    734
    735
    736
    737
    738
    739
    740
    741
    742
    743
    744
    745
    746
    747
    748
    749
    750
    751
    752
    753
    754
    755
    756
    757
    758
    759
    760
    761
    762
    763
    764
    765
    766
    767
    768
    769
    770
    771
    772
    773
    774
    775
    776
    -- Company:
    -- Engineer:
    -- Create Date:    14:39:53 07/27/2017
    -- Design Name:
    -- Module Name:    FSM_all - Behavioral
    -- Project Name:
    -- Target Devices:
    -- Tool versions:
    -- Description:
    -- Dependencies:
    -- Revision:
    -- Revision 0.01 - File Created
    -- Additional Comments:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    -- Uncomment the following library declaration if using
    -- arithmetic functions with Signed or Unsigned values
    use IEEE.NUMERIC_STD.ALL;
    -- Uncomment the following library declaration if instantiating
    -- any Xilinx primitives in this code.
    --library UNISIM;
    --use UNISIM.VComponents.all;
    entity FSM_all is
        GENERIC (L : INTEGER := 3;                  -- L is level of DWT
                    N : integer := 256;             -- N x N is image size
                    logN : INTEGER := 8;            -- log10(N)/log10(2) gives n bits that can address N
                    LLrow : INTEGER := 16;          -- N/2^(L+1) Range (0 TO LLrow-1)
                    word_length : integer := 11);
        Port ( rst,clk : in  STD_LOGIC;
               i : in  STD_LOGIC_VECTOR (7 downto 0);
                  out_en : OUT std_logic;
               y : out  STD_LOGIC_VECTOR (word_length-1 downto 0));
    end FSM_all;
    architecture Behavioral of FSM_all is
                            -- SRA FUNCTION --
        function "sra" (l : signed; r : natural) return signed is
            alias l_a : signed(l'length-1 downto 0) is l;
        begin
            return resize(l_a, l_a'length + r)(l_a'length+r-1 downto r);
        end function "sra";
                            --- RAM SIGNALS ---
        TYPE ram_type IS ARRAY (N*N-1 DOWNTO 0) OF STD_LOGIC_VECTOR(word_length-1 DOWNTO 0);
       SIGNAL RAM1: ram_type;
        SIGNAL RAM2: ram_type;
        SIGNAL we1,en1,we2,en2 : STD_LOGIC :='0';
        SIGNAL addr1,addr2 : INTEGER RANGE 0 TO N*N-1 := 0;
        SIGNAL di1,do1,di2,do2 : STD_LOGIC_VECTOR(word_length-1 DOWNTO 0):= (OTHERS => '0');
                            --- FSM SIGNALS ---
        TYPE state IS (fill_ram,dwt1d,idwt1d,dwt2d,idwt2d,initialize_SPIHT,load_b0,load_coef,ref_bitstream,sorting,output);
        SIGNAL pr_state: state;
                            --- DWT SIGNALS ---
        SIGNAL s1,x2k,s2,s23,s3 : signed(word_length-1 downto 0);
                            --- DEBUGGING SIGNALS ---
        SIGNAL db_addr : INTEGER RANGE 0 TO N*N/4-1 := 0;
                            --- SPIHT SIGNALS ---
                            ---(N*N/(2**(2*L))-1) L=3,N=256 =>1023
        SIGNAL b0 : STD_LOGIC_VECTOR(N*N/4 - 1 downto 0) := (OTHERS => '0') ;--Current block significant
        SIGNAL b1, b2 : STD_LOGIC_VECTOR(N*N/16 - 1 downto 0);-- b1:if all des sig or not, b2: typeA or B
        SIGNAL threshold : INTEGER RANGE 0 TO word_length-1;
        SIGNAL init_thrsh : signed(word_length-1 downto 0) := (OTHERS => '0');
        SIGNAL b0_addr : INTEGER RANGE 0 TO N*N/4-1 := 0;
    begin
                            --- RAM1 INITIALIZATION HERE ---
        ram1_init : PROCESS(clk)
                        BEGIN
                            if clk'event AND clk = '1' then
                                if en1 = '1' then
                                    if we1 = '1' then
                                        RAM1(addr1) <= di1;
                                    else
                                        do1 <= RAM1(addr1);
                                    end if;
                                end if;
                            end if;
                        END PROCESS ram1_init;
                            --- RAM2 INITIALIZATION HERE ---
        ram2_init : PROCESS(clk)
                        BEGIN
                                if en2 = '1' then
                                    if we2 = '1' then
                                        RAM2(addr2) <= di2;
                                    else
                                        do2 <= RAM2(addr2);
                                    end if;
                                end if;
                            end if;
                        END PROCESS ram2_init;
                            ----- FSM STARTS FROM HERE ----
                            ----- Main Section of FSM -----
        Main:           PROCESS(clk,rst)
                            ----DWT VARIABLES----
                            variable di_temp,di_temp1 : STD_LOGIC_VECTOR(word_length-1 downto 0);
                            variable adr,ram_out,ram_out1,alt1,alt5 : STD_LOGIC := '0';
                            variable ram_out2 : STD_LOGIC_VECTOR(1 downto 0) := "00";
                            variable addr2_1,addr2_2,addr1_1,addr1_2,addr1_3,addr1_4,a_temp,b_temp : INTEGER RANGE 0 TO N*N-1 := 0;
                            variable v1,v3 : signed(word_length-1 downto 0) := (OTHERS => '0');
                            variable v2 : signed(word_length-1 downto 0);
                            variable count_1,count : INTEGER RANGE 0 TO 7 := 0;
                            variable row,col1,col2,c_col1,c_col2 : INTEGER RANGE 1 TO N := 1;
                            variable M : INTEGER RANGE 0 TO N := N;
                            variable level : INTEGER RANGE 0 TO 5 := 1;
                            variable thrsh : STD_LOGIC_VECTOR(word_length-2 downto 0);
                            ----SPIHT VARIABLES----
                        BEGIN
                            IF clk'EVENT AND clk = '1' THEN
                                IF rst = '0' THEN
                                    CASE pr_state IS
                    ------- DWT Stages -----------
                                        WHEN fill_ram => -- Take 1D DWT Directly and fill into RAM2
                                            out_en <= '0';
                                            di_temp(word_length-1 downto 8) := (OTHERS => '0');
                                    --      di_temp(5 downto 0) := (OTHERS => '0');
                                            di_temp(7 downto 0) := i;
                                            if adr = '0' then
                                                adr := '1';
                                                addr1 <= 0;
                                                addr2 <= 0;
                                                addr2_1 := 0;
                                                addr2_2 := M*M/2;
                                                ram_out := '0';count := 0;
                                            end if;
                                            if count = 0 then
                                                count := count + 1;
                                            elsif alt5 = '1' then
                                                s1 <= signed(di_temp1);
                                                x2k <= signed(di_temp);
                                                v1 := s1 + x2k;
                                                s2 <= v1 sra 1;
                                                v2 := s1 - x2k;
                                                s23 <= v2 sra 1;
                                                alt5 := NOT alt5;
                                            else
                                                alt5 := NOT alt5;
                                                di_temp1 := di_temp;
                                            end if;
                                            s3 <= s23;
                                            if ram_out = '0' then
                                                if count_1 >= 6 then
                                                    we2 <= '1'; en2 <= '1';
                                                    di2 <= std_logic_vector(s2);
                                                    addr2 <= addr2_1;
                                                    addr2_1 := addr2_1 + 1;
                                                    ram_out := '1';
                                                else
                                                    count_1 := count_1 + 1;
                                                end if;
                                            else
                                                addr2 <= addr2_2;
                                                addr2_2 := addr2_2 + 1;
                                                di2 <= std_logic_vector(s3);
                                                ram_out := '0';
                                                if addr2_2 = M*M then
                                                    pr_state <= dwt2d;
                                                    alt5 := '0';
                                                    count_1 := 0;
                                                    adr := '0';
                                                    s1 <= (OTHERS => 'Z');s2 <= (OTHERS => 'Z');
                                                    s3 <= (OTHERS => 'Z');
                                                    x2k <= (OTHERS => 'Z');
                                                end if;
                                            end if;
                                        WHEN dwt1d =>
                                            out_en <= '0';
                                            we1 <= '0';
                                            if adr = '1' then
                                                addr1 <= 0;
                                                count := 0;
                                                adr := '0';a_temp := 0;
                                                addr2_1 := 0;col1 := 1;
                                                addr2_2 := M*M/2;row := 1;
                                                ram_out := '0';alt5 := '0';
                                                di_temp1 := (OTHERS => 'Z');
                                            elsif col1 <= M then
                                                if row < M then
                                                    if row = 1 then
                                                        a_temp := addr1;
                                                    end if;
                                                    addr1 <= addr1 + 1;
                                                    row := row + 1;
                                                else
                                                    row := 1;
                                                    if col1 < M then
                                                        addr1 <= a_temp + N;
                                                    end if;
                                                    col1 := col1 + 1;
                                                end if;
                                            end if;
                                            if count <= 1 then
                                                count := count + 1;
                                                x2k <= signed(do1);
                                                v1 := s1 + x2k;
                                                s2 <= v1 sra 1;
                                                v2 := s1 - x2k;
                                                s23 <= v2 sra 1;
                                                alt5 := NOT alt5;
                                            else
                                                alt5 := NOT alt5;
                                                di_temp1 := do1;
                                            end if;
                                            s3 <= s23;
                                                    addr2 <= addr2_1;
                                                    ram_out := '1';
                                                else
                                                end if;
                                            else
                                                addr2 <= addr2_2;
                                                ram_out := '0';
                                                    pr_state <= dwt2d;
                                                    alt5 := '0';
                                                    count_1 := 0;
                                                end if;
                                            end if;
                                        WHEN dwt2d =>
                                            out_en <= '0';
                                            we2 <= '0';
                                            if adr = '0' then
                                                addr2 <= 0;
                                                row := 1;
                                                col1 := 1;
                                                adr := '1';
                                                addr1_1 := 0;
                                                addr1_2 := M*N/2;
                                                addr1_3 := M/2;
                                                addr1_4 := M*(N+1)/2;
                                                ram_out := '0';
                                                count_1 := 0;count := 0;
                                            elsif row < M then
                                                row := row + 1;
                                                addr2 <= addr2 + M/2;
                                            elsif row = M then
                                                if col1 < M/2 then
                                                    col1 := col1 + 1;
                                                    addr2 <= col1 - 1;
                                                    row := 1;
                                                elsif col1 = M/2 then
                                                    col1 := col1 + 1;
                                                    col2 := 1;
                                                    addr2 <= M*M/2;
                                                    row := 1;
                                                else
                                                    if col2 < M/2 then
                                                        col2 := col2 + 1;
                                                        addr2 <= M*M/2 + col2-1;
                                                        row := 1;
                                                    end if;
                                                end if;
                                            end if;
                                            if count <= 1 then
                                                count := count + 1;
                                                x2k <= signed(do2);
                                                v1 := s1 + x2k;
                                                s2 <= v1 sra 1;
                                                v2 := s1 - x2k;
                                                s23 <= v2 sra 1;
                                                alt5 := NOT alt5;
                                            else
                                                alt5 := NOT alt5;
                                                di_temp1 := do2;
                                            end if;
                                            s3 <= s23;
                                            if s23(word_length-1) = '0' then
                                                if s23 > v3 then
                                                    v3 := s23;
                                                end if;
                                            end if;
                                            if s2(word_length-1) = '0' then
                                                if s2 > v3 then
                                                    v3 := s2;
                                                end if;
                                            end if;
                                            init_thrsh <= v3;
                                            if ram_out2 = "00" then
                                                    we1 <= '1'; en1 <= '1';
                                                    di1 <= std_logic_vector(s2);
                                                    if c_col1 = 1 then
                                                        addr1_1 := a_temp;
                                                        c_col1 := c_col1 + 1;
                                                    elsif c_col1 = M/2 then
                                                        a_temp := a_temp + 1;
                                                        c_col1 := 1;
                                                        addr1_1 := addr1_1 + N;
                                                    else
                                                    end if;
                                                    addr1 <= addr1_1;
                                                    ram_out2 := "01";
                                                else
                                                    a_temp := 0;
                                                end if;
                                            elsif ram_out2 = "01" then
                                                addr1 <= addr1_2;
                                                ram_out2 := "00";
                                                    if c_col2 < M/2 then
                                                        if c_col2 = 1 then
                                                            b_temp := addr1_2;
                                                        end if;
                                                        c_col2 := c_col2 + 1;
                                                        addr1_2 := addr1_2 + N;
                                                    else
                                                        if addr1_2 = N*(M-1) + M/2 -1 then
                                                            ram_out2 := "10";
                                                            count_1 := 0;
                                                            c_col1 := 1;
                                                            c_col2 := 1;
                                                            alt1 := '0';
                                                        else
                                                            addr1_2 := b_temp + 1;
                                                        end if;
                                                        c_col2 := 1;
                                                    end if;
                                                di1 <= std_logic_vector(s3);
                                            elsif ram_out2 = "10" then
                                                addr1 <= addr1_3;
                                                if c_col1 < M/2 then
                                                    if c_col1 = 1 then
                                                        a_temp := addr1_3;
                                                    end if;
                                                    addr1_3 := addr1_3 + N;
                                                else
                                                    addr1_3 := a_temp + 1;
                                                    c_col1 := 1;
                                                end if;
                                                ram_out2 := "11";
                                            else
                                                addr1 <= addr1_4;
                                                ram_out2 := "10";
                                                    if c_col2 = 1 then
                                                        b_temp := addr1_4;
                                                    end if;
                                                    addr1_4 := addr1_4 + N;
                                                else
                                                    if addr1_4 = N*(M-1) + M - 1 then
                                                        ram_out2 := "00";
                                                        count_1 := 0;
                                                        if level < L then
                                                            pr_state <= dwt1d;
                                                            level := level + 1;
                                                            alt5 := '0';
                                                            M := M/2;
                                                        else
                                                            pr_state <= initialize_SPIHT;
                                                            alt5 := '0';count_1 := 0;
                                                            level := 1;addr2_2 := 0;
                                                            addr2 <= 0;row := 1;
                                                            count := 0;addr2_1 := 0;
                                                        end if;
                                                    end if;
                                                    addr1_4 := b_temp + 1;
                                                    c_col2 := 1;
                                                end if;
                                            end if;
                    ------- SPIHT STAGES ----------------
                    ------- REFINEMENT PASS -------------
                                        WHEN initialize_SPIHT =>
                                            if row <= 2*LLrow then
                                                b0(addr2_2 + 2*LLrow-1 downto addr2_2) <= (OTHERS => '1');
                                                row := row + 1;
                                                if count_1 <= word_length-1 then
                                                    if init_thrsh(word_length-1-count_1) = '1' then
                                                        threshold <= word_length-1-count_1;
                                                    else
                                                    end if;
                                                end if;
                                            else
                                                pr_state <= load_b0;
                                            end if;
                                            addr1 <= 0;
                                        WHEN load_b0 =>
                                            we1 <= '0';we2 <= '0';
                                            if b0_addr < N*N/4 then
                                                if b0_addr <= N*N/4-9 then
                                                    if b0(b0_addr+7 downto b0_addr) = "00000000" then
                                                        b0_addr <= b0_addr + 8;
                                                    elsif b0(b0_addr) = '1' then
                                                        pr_state <= load_coef;
                                                    else
                                                        b0_addr <= b0_addr + 1;
                                                    end if;
                                                else
                                                    else
                                                    end if;
                                                end if;
                                            else
                                                pr_state <= sorting;
                                                b0_addr <= 0;
                                            end if;
                                            db_addr <= b0_addr;
                                        WHEN load_coef =>
                                            if count = 0 then
                                                addr1 <= to_integer(to_unsigned(b0_addr,2*logN) sll 1) + to_integer((to_unsigned(b0_addr,2*logN) srl logN-1) sll logN);
                                            elsif count = 2 then
                                                addr1 <= addr1 + N - 1;
                                            else
                                                addr1 <= addr1 + 1;
                                            end if;
                                            pr_state <= ref_bitstream;
                                        WHEN ref_bitstream =>
                                            if do1(word_length-1) = '1' then
                                                di_temp := std_logic_vector(-signed(do1));
                                            else
                                                di_temp := do1;
                                            end if;
                                            if di_temp(threshold) = '1' then ---SIGNIFICANT AT THIS THRESHOLD
                                                thrsh := (OTHERS => '0');
                                                thrsh(threshold) := '1';
                                                if di_temp(word_length-2 downto 0) > thrsh then
                                                    a_temp := 1;
                                                else
                                                    a_temp := 0;
                                                end if;
                                                if  a_temp = 0 then ---NOT ALREADY SIGNIFICANT COEFFICIENT
                                                    if addr2_1 = word_length-1 then --- can hold only one more bit
                                                        di_temp1(addr2_1) := do1(word_length-1);
                                                        di2 <= di_temp1;
                                                        addr2 <= addr2 + 1;
                                                        we2 <= '1';
                                                        addr2_1 := 0;
                                                        di_temp1(addr2_1) := di_temp(threshold);
                                                        addr2_1 := 1;
                                                    elsif addr2_1 = word_length-2 then
                                                        di2 <= di_temp1;
                                                        addr2 <= addr2 + 1;
                                                        we2 <= '1';
                                                        addr2_1 := 0;
                                                    else
                                                        addr2 <= addr2 + 1;
                                                        we2 <= '0';
                                                    end if;
                                                else ---- ALREADY SIGNIFICANT COEFFICIENT
                                                        di2 <= di_temp1;
                                                        addr2 <= addr2 + 1;
                                                        we2 <= '1';
                                                        addr2_1 := 0;
                                                    else
                                                        we2 <= '0';
                                                    end if;
                                                end if;
                                            else --- NOT SIGNIFICANT AT THIS THRESHOLD
                                                    di2 <= di_temp1;
                                                    addr2 <= addr2 + 1;
                                                    we2 <= '1';
                                                    addr2_1 := 0;
                                                else
                                                    we2 <= '0';
                                                end if;
                                            end if;
                                            if count = 3 then
                                                b0_addr := b0_addr + 1;
                                                count := 0;
                                            else
                                                count := count + 1;
                                            end if;
                                        WHEN sorting =>
                                            pr_state <= idwt1d;
                    -------- IDWT STAGES ----------------
                                        WHEN idwt1d =>
                                            we1 <= '0';en1 <= '1';
                                            out_en <= '0';
                                            if adr = '1' then
                                                ram_out2 := "00";
                                                adr := '0';
                                                ram_out1 := '0';
                                                addr1_1 := 0;
                                                addr1_2 := M*N/2;
                                                addr1_3 := M/2;
                                                addr2 <= 0;a_temp := 0;
                                                alt1 := '0';c_col2 := 1;
                                                c_col1 := 1; alt5 := '0';
                                        --      s1 <= (OTHERS => 'Z'); do1 <= (OTHERS => 'Z');do1 <= (OTHERS => 'Z');
                                            end if;
                                                we1 <= '0'; en1 <= '1';
                                                if c_col1 = 1 then
                                                    addr1_1 := a_temp;
                                                    c_col1 := 1;
                                                else
                                                end if;
                                                addr1 <= addr1_1;
                                                ram_out2 := "01";
                                                addr1 <= addr1_2;
                                                ram_out2 := "00";
                                                        if c_col2 = 1 then
                                                            b_temp := addr1_2;
                                                        end if;
                                                    else
                                                            ram_out2 := "10";
                                                            c_col1 := 1;
                                                            c_col2 := 1;
                                                            alt1 := '0';
                                                        else
                                                        end if;
                                                        c_col2 := 1;
                                                    end if;
                                                addr1 <= addr1_3;
                                                    if c_col1 = 1 then
                                                        a_temp := addr1_3;
                                                    end if;
                                                else
                                                    c_col1 := 1;
                                                end if;
                                                ram_out2 := "11";
                                            else
                                                addr1 <= addr1_4;
                                                ram_out2 := "10";
                                                    if c_col2 = 1 then
                                                        b_temp := addr1_4;
                                                    end if;
                                                else
                                                        ram_out2 := "11";
                                                    else
                                                        c_col2 := 1;
                                                    end if;
                                                end if;
                                            end if;
                                            if count <= 1 then
                                                count := count + 1;
                                                x2k <= signed(do1);
                                                s2 <= s1 + x2k;
                                                s23 <= s1 - x2k;
                                                alt5 := NOT alt5;
                                            else
                                                alt5 := NOT alt5;
                                                di_temp1 := do1;
                                            end if;
                                            s3 <= s23;
                                                we2 <= '1';
                                                    ram_out := '1';
                                                else
                                                    ram_out := '0';
                                                end if;
                                                if count_1 <= 7 then
                                                    addr2 <= 0;
                                                else
                                                    if row < M then
                                                        row := row + 1;
                                                    elsif row = M then
                                                        if col1 < M/2 then
                                                            col1 := col1 + 1;
                                                            addr2 <= col1 - 1;
                                                            row := 1;
                                                            col1 := col1 + 1;
                                                            col2 := 1;
                                                            addr2 <= M*M/2;
                                                            row := 1;
                                                        else
                                                            if col2 < M/2 then
        col2 := col2 + 1;
        row := 1;
                                                            elsif col2 = M/2 then
        pr_state <= idwt2d;
                                                            end if;
                                                        end if;
                                                    end if;
                                                end if;
                                            else
                                                count_1 := count_1 + 1;we2 <= '0';
                                                row := 1;col1 := 1;col2 := 1;ram_out := '0';
                                            end if;
                                        WHEN idwt2d =>
                                            out_en <= '0';
                                            we2 <= '0';
                                            if adr = '0' then
                                                adr := '1';
                                                addr1 <= 0;
                                                addr1_1 := 0;
                                                addr2 <= 0;
                                                count_1 := 0;
                                                count := 0;
                                                col1 := 1;
                                                addr2_1 := 0;alt5 := '0';
                                                addr2_2 := M*M/2;alt5 := '0';
                                                ram_out := '0';col1 := 1;ram_out1 := '0';
                                            end if;
                                                addr2 <= addr2_1;
                                                ram_out := '1';
                                            else
                                                addr2 <= addr2_2;
                                                if addr2_2 = M*M-1 then
                                                    ram_out := '1';
                                                else
                                                    ram_out := '0';
                                                end if;
                                            end if;
                                            if count <= 1 then
                                                count := count + 1;
                                                x2k <= signed(do2);
                                                s2 <= s1 + x2k;
                                                s3 <= s1 - x2k;
                                                alt5 := NOT alt5;
                                            else
                                                alt5 := NOT alt5;
                                                di_temp1 := do2;
                                            end if;
                                                we1 <= '1';en1 <= '1';
                                                if ram_out1 = '0' then
                                                    ram_out1 := '1';
                                                else
                                                    ram_out1 := '0';
                                                end if;
                                                if count_1 <= 6 then
                                                    addr1 <= 0;
                                                    if row < M then
                                                        if row = 1 then
                                                            a_temp := addr1;
                                                        end if;
                                                        addr1 <= addr1 + 1;
                                                        row := row + 1;
                                                    else
                                                        row := 1;
                                                        if col1 < M then
                                                        end if;
                                                        col1 := col1 + 1;
                                                    end if;
                                                else
                                                    if level = L then
                                                        pr_state <= output;
                                                    else
                                                        pr_state <= idwt1d;
                                                        level := level + 1;
                                                        M := 2*M;
                                                    end if;
                                                end if;
                                            else
                                                addr1 <= 0;a_temp := 0;row := 1;
                                                alt1 := '0'; col1 := 1;
                                            end if;
                    ----- OUTPUT STAGES ------
                                        WHEN output =>
                                            out_en <= '1';
                                                y <= (OTHERS => '0');
                                            else
                                                y(word_length-1 downto 0) <= do1(word_length-1 downto 0);
                                            end if;
                                            if alt1 = '0' then
                                                addr1_1 := 0;
                                                alt1 := '1';
                                            else
                                                addr1_1 := addr1_1 + 1;
                                                if addr1_1 = N*N then
                                                    pr_state <= fill_ram;
                                                end if;
                                            end if;
                                            addr1 <= addr1_1;
                                    END CASE;
                                END IF;
                            END IF;
                        END PROCESS Main;
    end Behavioral;
  8. #8
    dpaul's Avatar
    Jan 2008
    Germay
    1,028
    7,092
    20
    Blog Entries
    Quote Originally Posted by rafimiet View Post
    Without making things more complicated, lets come to your original problem....
    Why don't you use a generate statement to achieve the above(assuming x is a signal of type std_logic_vector)?
    array_gen : for i in 0 to 15 generate
    x(i*64 TO i*64+15) <= (others => '1');
    end generate array_gen;
    As Tricky mentioned in #2, it would be interesting to know what x is is!
    I can't go through your long code, but...
    This is not good. Allow extra states (I am sure your design can live with 2 or 3 clks of extra latency), let the signals update on the next clk, and then check their values in a new state.
    If you want FSM coding style from Xilinx- https://www.xilinx.com/support/docum...-pdf/lab10.pdf
    •   Alt13th September 2017, 09:06
      advertising
  9. #9
    Jun 2010
    6,485
    35,434
    45
    This post is all very confusing, as I dont understand how the original question relates to the huge code posted.
    This wont work, as this is not an initialisation, but just driving all the bits of X to constant 1. Its not clear what the OP means by initialisation - do you mean power up initialisation or initialisation as part of your running design. ie something writes all the addresses of a ram?
    Please clarify exactly what the problem is.
    As for comments on your code:
    1. Where are the comments?
    2. With few comments, signal naming is just annoying.
    3. Do you really need so many states?
    4. From my brief look, it looks like an attempt to port some software. Could you not have re-architected to make it more pipeline friendly?
