desgining a 28GHz patch antenna
sandeepkiranv
Hi, I would like to design a 28 GHz patch antenna in HFSS.....i have a doubt regarding radiation box...should i keep the general lambd/4 size radiation box? or else?.....
  • 1(1).rar
In general, I would propose using a half wave box (or sphere or cylinder). Lambda/4 is a little problematic in my view (too small). If possible, try (and error) with half wave box. Compare the results. If there is little difference in the S - Parameters (< about 5 %) it shouldn´t matter.
I had the same discussion with my professor, he also proposed half wave when structure is small and lambda/4 when structure is big. I somewhat share that view, but due to another aspect.
Seb
