Results 1 to 9 of 9
    Points: 248, Level: 2
    Jul 2017
    46
    248
    Cyclone ii fpga flash memory erasing
    How can i erase the epcs4n memory of cyclone ii?
    •   Alt12th September 2017, 09:33
      advertising
    Points: 11,924, Level: 26
    Aug 2011
    2,435
    11,924
    26
    Re: Cyclone ii fpga flash memory erasing
    via the programming application...
    Jul 2017
    46
    248
    Quote Originally Posted by shaiko View Post
    Are you talking about the erase option available in the Quartus software?...
    But once i erase the flash using the above option the program is still there in the fpga.
    Points: 34,223, Level: 45
    Jun 2010
    6,269
    34,223
    45
    Does the flash have multiple partitions?
    Often the dev boards have switches to select which partition is used during programming/loading.
    •   Alt12th September 2017, 11:26
      advertising
    Jul 2017
    46
    248
    Quote Originally Posted by TrickyDicky View Post
    Dev board used is cyclone ii and i have configured EPCS4N for the AS programming.
    Points: 233,653, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    40,361
    233,653
    100
    Which one, there many different types?
  7. #7
    Jul 2017
    46
    248
    Cyclone II EP2C02F484C7, and the configuring flash memory device is EPCS4N
  8. #8
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    40,361
    233,653
    100
    I was asking for the development board type, not the FPGA. Knowing the board allows to check for specific configuration features, switches, etc.
    EP2C20 sounds like Altera Cyclone II Starter Board alias Terasic DE1.
    •   Alt13th September 2017, 05:30
      advertising
  9. #9
    Jul 2017
    46
    248
    its DE01 cyclone ii dev board
