+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 3
    Points: 367, Level: 4
    Join Date
    Jul 2017
    Posts
    58
    Points
    367
    Level
    Cyclone ii fpga flash memory erasing
    How can i erase the epcs4n memory of cyclone ii?
    •   Alt12th September 2017, 09:33
      advertising
  2. #2
    Advanced Member level 5
    Points: 12,223, Level: 26
    Join Date
    Aug 2011
    Posts
    2,484
    Points
    12,223
    Level
    26
    Re: Cyclone ii fpga flash memory erasing
    via the programming application...
  3. #3
    Member level 3
    Join Date
    Jul 2017
    Posts
    58
    Points
    367
    Level
    Quote Originally Posted by shaiko View Post
    Are you talking about the erase option available in the Quartus software?...
    But once i erase the flash using the above option the program is still there in the fpga.
    •   Alt12th September 2017, 11:04
      advertising
  4. #4
    Points: 35,434, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,485
    Points
    35,434
    Level
    45
    Does the flash have multiple partitions?
    Often the dev boards have switches to select which partition is used during programming/loading.
    •   Alt12th September 2017, 11:26
      advertising
  5. #5
    Member level 3
    Join Date
    Jul 2017
    Posts
    58
    Points
    367
    Level
    Quote Originally Posted by TrickyDicky View Post
    Dev board used is cyclone ii and i have configured EPCS4N for the AS programming.
  6. #6
    Super Moderator
    Points: 239,566, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,505
    Points
    239,566
    Level
    100
    Which one, there many different types?
  7. #7
    Member level 3
    Join Date
    Jul 2017
    Posts
    58
    Points
    367
    Level
    Quote Originally Posted by FvM View Post
    Cyclone II EP2C02F484C7, and the configuring flash memory device is EPCS4N
  8. #8
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,505
    Points
    239,566
    Level
    100
    I was asking for the development board type, not the FPGA. Knowing the board allows to check for specific configuration features, switches, etc.
    EP2C20 sounds like Altera Cyclone II Starter Board alias Terasic DE1.
    •   Alt13th September 2017, 05:30
      advertising
  9. #9
    Member level 3
    Join Date
    Jul 2017
    Posts
    58
    Points
    367
    Level
    its DE01 cyclone ii dev board
