Using a buffer to modify an input port
mahmood.n
Member level 5
May I ask why the following code doesn't work?
entity test is
	port( a: buffer std_logic_vector(2 downto 0);
				clk: in std_logic);
end;
architecture my of test is
begin
	process( clk )
	begin
	    if (clk'event and clk = '1') then
                 a <= a(1 downto 0) & '0';
  	    end if;
	end process;
end;
If a=011 then the value of a won't change over the clock.
Well I want to modify the input value, e.g. add with 1 or shift by n bit. with "in" type, it is not allowed.
Why would you modify an input? It is coming in, not going out, so whats going to read it?>
Buffer type is an output. The circuit has no input other than clk.
Well assume the input port receives a number (std_logic_vector) and I want to manipulate it. The following doesn't work either
entity test is
	port( a: in std_logic_vector(2 downto 0);
			clk: in std_logic;
			z: out std_logic_vector(2 downto 0));
end;
	signal tmp : std_logic_vector(2 downto 0) := a;
begin			 																								process( clk )
	begin
                  tmp <= tmp(1 downto 0) & '0';
  	end if;
	z <= tmp;
	end process;
end;
That initialized tmp at the time of synthesis for power up only. (in ASIC synthesis it is ignored)
You have to assign a to tmp using an if statement and some control signal to signal you are loading tmp with the a input.
e.g.
Code VHDL - [expand]
8
9
10
11
process (clk)
begin
  if rising_edge(clk) then
    if (load_a = '1') then
      tmp <= a;
    else
    end if;
  end if;
end process;
z <= tmp;
OK I understand that. That method is works as I tested.
Apart from the synthesis issues and rules of variable vs. signal, I wonder why using variable doesn't fully work! I know it doesn't make sense, but at least I have to see a working code!
entity test is
			clk: in std_logic;
end;
		variable tmp: std_logic_vector(2 downto 0) := a;
	begin
			tmp := tmp(1 downto 0) & '0';
			z <= tmp;
		end if;
	end process;
end;
But z is not valid in the first three cycles as picture shows.
update
I think you are still suffering from a conceptual misunderstanding of how VHDL code represents the physical gate level design of digital circuits. Unless you code things like multiplexers (if statements, or case statements) you won't have logic to load a register.
Maybe you should pick up a copy of HDL Chip Design by Douglas Smith, which has nice side by side code of both VHDL and Verilog along with gate level output of a synthesis tool for the code.
Yeah it's invalid because z is never assigned anything until the '0' is shifted through.
I really can't stomach code with variables used as registers.
Here, tmp is initialised to a at time zero. At time zero, A is "UUU" (which is what tmp would have been if not assigned an initial value).
Hence why you see 'U' on the Z port for 3 cycles before '0' propgates. After 3 clocks, Z will always be 0. The a input here is redundant and unused.
Well the variable has been initialized. Thing is that, instead of initializing to a constant value, e.g. "000", I wrote a. If I use "000", then the output in the first three cycles become zero.
You said that
, so I thought such thing is valid for signals only and variables should accept such initialization. Thanks.
You can't initialize using a non-constant value it is ignored by synthesis tools, I'm somewhat surprised it didn't throw an error or warning.
Hmm, you did look at the warnings, critical warnings, errors generated by the tools...
