+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Member level 4
    Points: 1,449, Level: 8
    Join Date
    Dec 2011
    Posts
    77
    Points
    1,449
    Level
    8
    Using a buffer to modify an input port
    May I ask why the following code doesn't work?
    entity test is
    	port( a: buffer std_logic_vector(2 downto 0);
    				clk: in std_logic);
    end;
    architecture my of test is
    begin
    	process( clk )
    	begin
    	    if (clk'event and clk = '1') then
                     a <= a(1 downto 0) & '0';
      	    end if;
    	end process;
    end;
    If a=011 then the value of a won't change over the clock.
    •   Alt11th September 2017, 15:54
      advertising
  2. #2
    Points: 7,096, Level: 20
    Achievements:
    7 years registered Created Blog entry
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    1,029
    Points
    7,096
    Level
    20
    Blog Entries
    Re: Using a buffer to modify an input port
    Are you sure you want to use a buffer type?
    Read this: http://www.edaboard.com/thread259349.html
    .....yes, I do this for fun!
  3. #3
    Member level 4
    Join Date
    Dec 2011
    Posts
    77
    Points
    1,449
    Level
    8
    Well I want to modify the input value, e.g. add with 1 or shift by n bit. with "in" type, it is not allowed.
  4. #4
    Advanced Member level 5
    Points: 35,434, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,485
    Points
    35,434
    Level
    45
    Why would you modify an input? It is coming in, not going out, so whats going to read it?>
    •   Alt11th September 2017, 16:52
      advertising
  5. #5
    Super Moderator
    Points: 239,566, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,505
    Points
    239,566
    Level
    100
    Buffer type is an output. The circuit has no input other than clk.
    •   Alt11th September 2017, 16:58
      advertising
  6. #6
    Member level 4
    Join Date
    Dec 2011
    Posts
    77
    Points
    1,449
    Level
    8
    Well assume the input port receives a number (std_logic_vector) and I want to manipulate it. The following doesn't work either
    entity test is
    	port( a: in std_logic_vector(2 downto 0);
    			clk: in std_logic;
    			z: out std_logic_vector(2 downto 0));
    end;
    	signal tmp : std_logic_vector(2 downto 0) := a;
    begin			 																								process( clk )
    	begin
                      tmp <= tmp(1 downto 0) & '0';
      	end if;
    	z <= tmp;
    	end process;
    end;
  7. #7
    Super Moderator
    Points: 28,163, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,438
    Points
    28,163
    Level
    40
    That initialized tmp at the time of synthesis for power up only. (in ASIC synthesis it is ignored)
    You have to assign a to tmp using an if statement and some control signal to signal you are loading tmp with the a input.
    e.g.
    Code VHDL - [expand]
    8
    9
    10
    11
    process (clk)
    begin
      if rising_edge(clk) then
        if (load_a = '1') then
          tmp <= a;
        else
        end if;
      end if;
    end process;
    z <= tmp;
  8. #8
    Member level 4
    Join Date
    Dec 2011
    Posts
    77
    Points
    1,449
    Level
    8
    OK I understand that. That method is works as I tested.
    Apart from the synthesis issues and rules of variable vs. signal, I wonder why using variable doesn't fully work! I know it doesn't make sense, but at least I have to see a working code!
    entity test is
    			clk: in std_logic;
    end;
    		variable tmp: std_logic_vector(2 downto 0) := a;
    	begin
    			tmp := tmp(1 downto 0) & '0';
    			z <= tmp;
    		end if;
    	end process;
    end;
    But z is not valid in the first three cycles as picture shows.
  9. #9
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,438
    Points
    28,163
    Level
    40
    update
    I think you are still suffering from a conceptual misunderstanding of how VHDL code represents the physical gate level design of digital circuits. Unless you code things like multiplexers (if statements, or case statements) you won't have logic to load a register.
    Maybe you should pick up a copy of HDL Chip Design by Douglas Smith, which has nice side by side code of both VHDL and Verilog along with gate level output of a synthesis tool for the code.
    Yeah it's invalid because z is never assigned anything until the '0' is shifted through.
    I really can't stomach code with variables used as registers.
    1 members found this post helpful.
  10. #10
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,485
    Points
    35,434
    Level
    45
    Here, tmp is initialised to a at time zero. At time zero, A is "UUU" (which is what tmp would have been if not assigned an initial value).
    Hence why you see 'U' on the Z port for 3 cycles before '0' propgates. After 3 clocks, Z will always be 0. The a input here is redundant and unused.
  11. #11
    Member level 4
    Join Date
    Dec 2011
    Posts
    77
    Points
    1,449
    Level
    8
    Quote Originally Posted by TrickyDicky View Post
    Well the variable has been initialized. Thing is that, instead of initializing to a constant value, e.g. "000", I wrote a. If I use "000", then the output in the first three cycles become zero.
    You said that
    , so I thought such thing is valid for signals only and variables should accept such initialization. Thanks.
    •   Alt11th September 2017, 20:25
      advertising
  12. #12
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,438
    Points
    28,163
    Level
    40
    You can't initialize using a non-constant value it is ignored by synthesis tools, I'm somewhat surprised it didn't throw an error or warning.
    Hmm, you did look at the warnings, critical warnings, errors generated by the tools...
