Results 1 to 12 of 12
    Member level 5
    Points: 650, Level: 5
    Jul 2016
    94
    650
    5v to 3.3v, around 70mA current at output.
    hi,
    my application is to convert 5v to 3.3v and 70mA output.
    i am looking for smd package.
    i found AMS1117 3.3v voltage regulatorhttps://www.aliexpress.com/item/10pc...8-a8c4c473449a
    i am confused in selected section shown in image.
    is this sentence want to say that it will work when there is voltage difference of 1v? it will not work if 4v is input and output is 3.3v
    thanks,
    vraj
    •   Alt11th September 2017, 15:24
      advertising
    Points: 11,674, Level: 25
    Nov 2012
    2,188
    11,674
    25
    Re: 5v to 3.3v, around 70mA current at output.
    Quote Originally Posted by Vraj View Post
    Right. For 3.3V output, the input must be greater than 4.3V.
    Member level 5
    Jul 2016
    94
    650
    i found another one XC6206 662k.
    ams1117n was bigger in size.
    am i in correct direction?
    •   Alt12th September 2017, 13:58
      advertising
    Nov 2012
    2,188
    11,674
    25
    You will find very few regulators that have lower drop than 1V; the regulator needs some space to work. Perhaps you can get one with a 0.9V dropout but then they are rare.
    Anyway you will that 4V input cannot reliably produce 3.3V regulated output (most cases)
    Points: 47,554, Level: 53
    Most Frequent Poster
    Apr 2014
    9,719
    47,554
    53
    but what´s the problem? You want to convert 5V to 3.3V.
    And the 1117 operates with input voltages > 4.3V
    5.0V > 4.3V. --> True. Everything is fine.
    •   Alt12th September 2017, 15:38
      advertising
    Points: 5,655, Level: 17
    Jun 2015
    1,003
    5,655
    17
    Why not use any of many preset or adjustable LDOs - maybe easily covering the 300 to 700-ish mV dropout headroom only?
  7. #7
    Member level 5
    Jul 2016
    94
    650
    it was hard with another ics.
    i was using qfn 4*4 packge and 0402 packages. 1117 was looking bigger.
    XC6206 662k is available in sot23.
    amazing thing of XC6206 662k[/URL] is that, it is ceramic capacitor compatible.[URL="https://www.torexsemi.com/file/xc6206/XC6206.pdf"]
    may be they are used for smoothing i/p and o/p waves.
    my input is 5v from usb.
    i don't have oscilloscope, can you say that i should go with mentioned value of capacitor (as datasheet)?
    will capacitor rated with 10v will ok?
    Quote Originally Posted by d123 View Post
    present LDOs? e.g.?
    i need small smd package and cheaper one
    means?
  8. #8
    Apr 2014
    9,719
    47,554
    53
    I don't see this as drawback, I see it as benefit
    Every voltage regulator should have capacitors close at input and output to ensure stability.
    So your input voltage is not exactly 5.0V.
    Rather expect 4.2V ..... 5.5V (it is specified down to 4.5V, but I've seen many they go below this at the end of the cable)
    Keep on the datasheet recommendations.
    Yes.
    present LDOs? e.g.?
    Almost any true LDO with 3.3V output will do the job.
    There are hundreds of LDOs that can be used.
    I'd go to a distributor's or a manufacturer's web site selection guide to choos the right one.
    If you go to aliexpresss .... it's your way...
  9. #9
    Member level 5
    Jul 2016
    94
    650
    hi,
    My main MCU manufacturer has mentioned to add 4.7uF and 10nF capacitor to input 3.3v and ground.
    i think they mentioned to smooth i/p.
    my XC6206 662k is providing good o/p 3.3v with 1uF.
    i think, i should continue with 1uf and parallel with 10nF, avoiding 4.7uF.
    what's your opinion?
    i also meant impressive(amazing)
    thanks,
    vraj
    •   Alt13th September 2017, 09:05
      advertising
  10. #10
    Apr 2014
    9,719
    47,554
    53
    you must not rely on any MCU manufacturer recommendation when you want stable XC6206 operation.
    Rely on the XC6206 datasheet.
    it clearely says to use 1uF ceramics each at input and output.
    Additionally it says:
    3. Please wire the input capacitor (C IN ) and the output capacitor (C L ) as close to the IC as possible.
    4. Capacitances of these capacitors (C IN , C L ) are decreased by the influences of bias voltage and ambient temperature. Care
    shall be taken for capacitor selection to ensure stability of phase compensation from the point of ESR influence.
  11. #11
    Member level 5
    Jul 2016
    94
    650
    hi,
    i think there is misunderstanding.
    i mean my main ic is MCU. MCU is rated 3.3v input.
    i need stable MCU operation.
    if small capacitors like 10nF used to smooth remaining high frequency, then should i use?
    thanks,
    vraj
  12. #12
    Apr 2014
    9,719
    47,554
    53
    for stable MCU operation you need to follow the recommendations in the MCU datasheet.
    If they recommend to use 10nF capacitors then do so.
    But read carefully. Usually they recommend one capacitor very close at each VCC pin of the IC....this has nothing to do with the capacitors close to the voltage regulator.
