+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 3
    Points: 788, Level: 6
    Join Date
    May 2015
    Posts
    59
    Points
    788
    Level
    Difference between combinational path delay and minimum period
    After synthesizing, I get the static timing report as follows
       Minimum period: 7.577ns (Maximum Frequency: 131.987MHz)
       Minimum input arrival time before clock: 2.325ns
       Maximum output required time after clock: 2.826ns
       Maximum combinational path delay: 3.189ns
    I am using Finite State Machine of over 600 lines. Throughout the code I have tried my level best to minimize the combinational path delay using registers wherever required. Now I have a combinational delay of 3.189ns, which is acceptable. Can I know what delays are taken into consideration when calculating minimum period? Is there anything that I can do to increase the Maximum Frequency of my design? (So far I have not provided any constraints to the clock)
    •   Alt10th September 2017, 06:56
      advertising
  2. #2
    Advanced Member level 5
    Points: 34,876, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,390
    Points
    34,876
    Level
    45
    Re: Difference between combinational path delay and minimum period
    The maximum period will be a sum of the worst case setup and hold time in the design, which will be the combinarial path plus some of the input/output required times.
    To improve FMax, you need to reduce the combinatorial path delays. You can uses timing analysis to find out where the worst case paths are, and modify the code to improve the pipelining.
    Basically - less logic between registers = higher fmax.
    •   Alt10th September 2017, 07:41
      advertising
  3. #3
    Advanced Member level 3
    Points: 4,715, Level: 16
    Join Date
    Feb 2015
    Posts
    782
    Points
    4,715
    Level
    16
    There are a few possible issues:
    1.) Clock to out time of the source. This comes up in RAMs and shift-registers in some cases. Sometimes in other hard-ip. This is also important for IO. Many FPGA designs will use the IO registers in addition to one or more routing registers if desired.
    2.) Combinatorial logic. This gets harder to estimate as clock rate decreases and allowed complexity greatly increases. Put another way, it is easy to estimate if logic might run at 500MHz but difficulty to estimate if something is so complex it would not run at 100MHz.
    3.) Routing delays. This is the delays in connections between logic elements. In some cases this is due to physical constraints -- for example, routing to IO pins means the logic must be somewhat near that IO.
    4.) Congestion. This is related to the above -- in this case, the logic could work much faster, but some elements are placed too far apart. This is a case where routing delays could be lower in a smaller design. In some cases, this can be fixed by more efficient use of BRAM/DMEM/etc...
    IIRC, you should also provide a clock constraint. I forget if the tools will take too much effort to optimize your design otherwise.
    •   Alt10th September 2017, 08:15
      advertising
  4. #4
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,390
    Points
    34,876
    Level
    45
    Quote Originally Posted by vGoodtimes View Post
    It can be a good idea. At least with Quartus, with no constraints it assumes a 1GHz clock. An overconstraint like this can cause the fitter to give up early as it will never meet timing and might actually give you worse result than you would get with a realistic constraint.
    Its good for initial FMax on a single block, but should never be used for a final design.
