+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 4
    Points: 887, Level: 6
    Join Date
    May 2015
    Posts
    72
    Points
    887
    Level
    simulation in vivado vs ISIM(in Xilinx ISE)
    I have been using Xilinx ISE and ISIM for quite a few years now. But now, due to some reasons, I have to switch to Vivado. I can not find the simulation setup in vivado the same way as ISIM. Also I am not much familiar with Vivado. Firstly, ISE would auto generate the test bench, which needed small modifications to serve your purpose. Secondly there were manual simulations possible in ISIM. The test vectors were generated using the command PUT (for example: put a 10101010). Can I have similar kind of simulations in Vivado? Or has it become simpler in Vivado in any respect?
    •   Alt10th September 2017, 05:30
      advertising
  2. #2
    Points: 7,092, Level: 20
    Achievements:
    7 years registered Created Blog entry
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    1,028
    Points
    7,092
    Level
    20
    Blog Entries
    Re: simulation in vivado vs ISIM(in Xilinx ISE)
    Left-hand corner, Project Manager --> Settings will open up the Settings window. From there just select Simulation and you will get its options.
    I think you should read the latest version of the ug910-vivado-getting-started.pdf and play around with the tool for sometime.
    Vivado is much better, have fun!
    .....yes, I do this for fun!
    •   Alt11th September 2017, 09:28
      advertising
  3. #3
    Member level 4
    Join Date
    May 2015
    Posts
    72
    Points
    887
    Level
    But ISIM is not there. Is there a way to enter manual simulations?
    •   Alt11th September 2017, 12:16
      advertising
  4. #4
    Achievements:
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    1,028
    Points
    7,092
    Level
    20
    Blog Entries
    You now have everything integrated under Vivado suite.
    Please read the migrating to Vivado from ISE docu.
    https://www.xilinx.com/support/docum...-migration.pdf
    1 members found this post helpful.
