+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Member level 5
    Points: 992, Level: 7
    Join Date
    Mar 2014
    Posts
    89
    Points
    992
    Level
    7
    Run all Vivado synthesis strategies in one run
    Hello,
    Is there any way that I can synthesis my design using all the 8 synthesis strategies(optimized area, performance...) available in Vivado and have one synthesis report for each? Now the following TCL is the command that starts the synthesis.
    start_gui
    open_project /~/project_1/project_1.xpr
    launch_runs synth_1 -job 2
    I don't know if there is an option to choose the strategies from TCL? Also please let me know if I can loop through all the strategies. Thanks!
    Cheers!
    •   Alt9th September 2017, 14:25
      advertising
  2. #2
    Points: 7,092, Level: 20
    Achievements:
    7 years registered Created Blog entry
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    1,028
    Points
    7,092
    Level
    20
    Blog Entries
    Re: Run all Vivado synthesis strategies in one run
    Have you taken a look at the ug901, vivado-synthesis documentation?
    In there if you look at the details under "Running Synthesis with Tcl", the -directive switch allows you to choose various strategies.
    .....yes, I do this for fun!
