Current sweep. Current changing linearly.
Already written:
One problem is, that you now mix two problems:
1) how to build a current control circuit
2) generate a precise control voltage (wich is not your initial question) for the current control circuit. This - with a dynamic and precision of 1:1000 - can be done with a good voltage reference and at least a 10 bit DAC.
1 µA in a loop of 0.1 m radius gives only 6 pT. No problem to generate nT with reasonable current parameters, I think.
