+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Points: 72, Level: 1
    Join Date
    Aug 2017
    Posts
    8
    Points
    72
    Level
    Mentor Calibre nmDRC vs DRC
    Hi
    I am trying to install the latest version of Mentor's Calibre into a new workstation with Cadence. And I found that when I click calibre menu, it shows "run nmDRC" instead of "run DRC" same for "run nmLVS" instead of "LVS"
    Can anyone tell me what's the difference? Should I download a previous version or just use nmDRC?
    Thanks
    Allen
    •   Alt8th September 2017, 03:52
      advertising
  2. #2
    Member level 3
    Points: 1,008, Level: 7
    Join Date
    Nov 2013
    Posts
    60
    Points
    1,008
    Level
    7
    Re: Mentor Calibre nmDRC vs DRC
    Hi Allen-
    nmDRC/nmLVS can run all the old Calibre DRC/Calibre LVS files. The nm products can handle larger design sizes and TVF commands, which the older products didn't. There are also some features for better scalability, but you'd only be using those for batch runs.
    Best-
    Sam.
    •   Alt11th September 2017, 19:06
      advertising
  3. #3
    Join Date
    Aug 2017
    Posts
    8
    Points
    72
    Level
    Hi Sam,
    Thanks for the reply! Can I please ask a follow-up question? Do they use different licenses?
    I setup the license just like the old workstation(point the license server address) but calibre informed me that the product can not be licensed sufficiently. The license server was setup by someone else a while ago and I just wonder if Calibre nm product demand different license than old Calibre?
    Much obliged
    Allen
    •   Alt11th September 2017, 19:59
      advertising
  4. #4
    Member level 3
    Join Date
    Nov 2013
    Posts
    60
    Points
    1,008
    Level
    7
    Hi Allen-
    You don't mention specific versions, but chances are good that the license manager software (FlexLM) got updated. Calibre versions that announced a license server upgrade were 8.8_1 (August 2000) and v2010.1. There may have been others.
    Best-
    Sam.
