Difference between SCMOS and Vendor native Design Kits in MOSIS
bio_man
Full Member level 2
See "Processes That Also Support SCMOS Rules":
Use SCMOS for simplicity or portability of design means the design rules are a common subset of different similar (i.e. same process size) processes, possibly of different fabs/foundries. Hence they are not so strict as the vendor-specific rules.
Hence use SCMOS rules, if you want just a few chips (for design evaluation, on an MPW or on a single/few wafer(s)) or if you plan to possibly transfer your design to another process.
Use vendor-specific rules if you plan for high volume chip production (min. 1 wafer lot, ≈24 wafers). These rules are more strict and allow for denser (smaller) designs.
The problem is that when I submit an inquiry to MOSIS asking about the availability of native nMOS transistor in C5, they advised me to initiate an account and pointed out that it may be available in native vendor PDK. Now, I have my layout for the whole circuit prepared using SCMOS PDK, it seems I can't just include the native nMOS if I got the vendor PDK which means I need to redo the layout !! right? This is at least what I understand from this link : https://www.mosis.com/pages/design/rules/index
here is a screenshot:
and FYI, I am doing a prototype for my circuit which means SCMOS is much better to use.
SCMOS comes from a time when scaling was somewhat linear, you would just shrink the dimensions but gates would remain more or less similar. this is no longer true, e.g., finfets. No idea why MOSIS still keeps it in there, or why you would try to do a modern circuit using it.
In this case you must renounce on native nMOS. Anyway, it's not sure that ON semi offers native nMOS in their C5 process. At least I don't know.
We're talking of an ancient 0.5µm process. Still going strong, at least for design evaluation and prototyping on MPW wafers via MOSIS, Europractice ... on a regular basis.
For me, it is just a proof of concept for a circuit that I designed
why not an FPGA then? what is your design?
even when we want to prototype some custom design 'on the cheap', we use TSMC 65nm around here. 500nm technology is so... OLD.
you are right, it is old but it is funded by MOSIS through their educational program. I can't afford paying for fabrication. BTW, how much cheap is TSMC 65nm? for example, 500nm is around $1000/1mm2 without packaging.
It is DC-DC converter intended for power management in energy harvesting circuits.
last time we paid ~5k for 1 mm^2 of TSMC 65nm. with packaging.
I am not aware of C5 having native FETs, but other
ON flows (like ONC18) do have nvt (~0) and lvt (~0.3).
I have participated in ONC18 multiproject runs (for
ROICs) through ON directly (not MOSIS). You ought to
reach out to them, bypassing MOSIS, to see about the
economics.
ONC18 variant I was working with has 3.3V I/O devices
and 1.8V "core" devices. There may be a 5V I/O option,
I do not know - project was not interested in 5V.
