A slower gate drive rise/fall time will make a shorter
(but wider) edge overshoot. Applying realistic loading
(C) will soak up some of the gate charge. Using no
larger than necessary switch devices cuts gate charge
proportionally. Driving the gate no further than necessary
also can cut gate charge injection.
