GSM based three phase motor controller program problem
sribangaram
Full Member level 5
INDIA.:/;:'" VIJAYAWADA
Dear Friends i need small modification for my program this program working fine but i wont to add 3 phase detection when any phase will be fail or avail then send to sms and at the same time if motor in HIGH position immediately change to LOW position
PHP:
const int analogPin1 = PIN_A0;   // pin that the eb L1 sense
const int analogPin2 = PIN_A1;   // pin that the eb L2 sense
const int analogPin3 = PIN_A2;   // pin that the eb L3 sense
const int analogPin3 = PIN_A3;   // pin that the dry run sense
const int threshold = 1023;   // an arbitrary threshold level that's in the range of the analog input
int repeat = 0;
int LED = 8;
int motor = 9;
int buttonpushcounter =0;
int buttonstate =0;
int lastbuttonstate =0;
int temp=0;
int i=0;
char str[15];
void setup()
  Serial.begin(9600);
  pinMode(threshold , INPUT);
  pinMode(motor,OUTPUT);
  pinMode(LED,OUTPUT);
  digitalWrite(motor,LOW);
  digitalWrite(LED,LOW);
  delay(5000);
  delay(5000);
  delay(5000);
  Serial.println("AT+CNMI=2,2,0,0,0");
  delay(1000);
  Serial.println("AT+CMGF=1");
  delay(1000);
  // read the value of the potentiometer:
  int analog1Value = analogRead(analogPin1);
  int analog2Value = analogRead(analogPin2);
  int analog3Value = analogRead(analogPin3);
  Serial.println("Analog pin A0: " +String(analog1Value));
  Serial.println( "Analog pin A1: " +String(analog2Value));
  Serial.println("Analog pin A2: " +String(analog3Value));
  delay(1000);
void loop()
buttonstate = analogRead (threshold);
if (buttonstate != lastbuttonstate)
  if (buttonstate == threshold){
    buttonpushcounter ++;
    Serial.println("3 PHASE OK");
    delay(1000);
    //Serial.println("number of button pushes:");
    //Serial.println(buttonpushcounter);
    Serial.println("AT+CMGS=\"+919705422218\"\r"); // Replace x with mobile number
  delay(1000);
  Serial.println("system ready three phase available");// The SMS text you want to send
  delay(1000);
  Serial.println((char)26); // ASCII code of CTRL+Z
  delay(1000);
   } else {
    Serial.println("3 PHASE NOT OK");
    delay(1000);
      delay(1000);
  delay(1000);
  Serial.println("system ready but three phase not available");// The SMS text you want to send
  delay(1000);
  delay(1000);
  lastbuttonstate = buttonstate;
  if (buttonpushcounter % 1 ==0){
  if(temp==1)
    check();
    temp=0;
    i=0;
    delay(1000);
 void serialEvent()
  while(Serial.available())
    if(Serial.find("/"))
      delay(1000);
      while (Serial.available())
      char inChar=Serial.read();
      str[i++]=inChar;
      if(inChar=='/')
        temp=1;
        return;
void check()
   if(!(strncmp(str,"motor on",8)))
    {delay(1000);        // delay in between reads for stability
   if("analog1Value  threshold", "analog2Value  threshold", "analog3Value  threshold"){
    delay(100);        // delay in between reads for stability
      digitalWrite(motor,HIGH);
      digitalWrite(LED,HIGH);
      delay(1000);
      delay(1000);
      Serial.println("Motor Activated");// The SMS text you want to send
      delay(100);
      delay(1000);
       } else {
      delay(1000);
      delay(1000);
      Serial.println("Motor deactivated due to three phase not available");// The SMS text you want to send
      delay(100);
      delay(1000);
   else if(!(strncmp(str,"motor off",9)))
      delay(1000);
      delay(1000);
      Serial.println("Motor deactivated");// The SMS text you want to send
      delay(100);
      delay(1000);
else if(!(strncmp(str,"test",4)))
      delay(1000);
      Serial.println("The System is Working Fine.");// The SMS text you want to send
      delay(100);
      delay(1000);
