Results 1 to 5 of 5
    Newbie level 5
    Points: 199, Level: 2
    Dec 2016
    8
    199
    synthesis question about generated clocks
    Hi, if for example i have two clocks then they are connected to a mutiplexer, should i declare the output as a generated clock?
    •   Alt4th September 2017, 03:30
      advertising
    Advanced Member level 3
    Points: 4,627, Level: 16
    Apr 2016
    974
    4,627
    16
    Re: synthesis question about generated clocks
    not needed. just make different sdcs and use set_case_analysis for each clock mode
    Really, I am not Sam.
    •   Alt4th September 2017, 16:05
      advertising
    Points: 1,735, Level: 9
    Jan 2009
    Boston, MA
    37
    1,735
    9
    Quote Originally Posted by ThisIsNotSam View Post
    If you do nothing wouldn't dc_compiler time the corresponding registers with both clocks?
    •   Alt14th September 2017, 18:19
      advertising
    Apr 2016
    974
    4,627
    16
    Quote Originally Posted by TonyLS View Post
    no, it will do either one or the other
    Full Member level 5
    Points: 3,829, Level: 14
    Jan 2007
    258
    3,829
    14
    If you set in DC variable timing_enable_multiple_clocks_per_reg to true, the tool will time the registers with both clocks. So, it will save runtime - you have timing for both clocks in on session (do not need to switch set_case_analysis). But, you may have timing from one clock to the other - call them asynchronous or set false path between them. It's up to you.
