kappa_am
Full Member level 6
Hi all,
I am using 3 SKHI22B drivers to fire a 75A, 1200V IGBT brick (3 phase). Unfortunately, there is no way to shorten the distance between driver and the module brick (it's about 30cm). I am afraid that this length would lead to a problem ( oscillating with gate capacitor, causing IGBT works in the linear region...).
I would be grateful if you share your idea to minimize the effect of the connection wire on the firing and IGBT performance.
Thank you
Thank you
