layout versus schematic verification
atlaakreddy
Junior Member level 2
what is the difference between the spice netlist,lvs.v,schematic netlist?please expalin withe detail?
what is the formate of spicenetlist, normal netlist, schematicnetlist, lvs.v?
LVS means layout versus schematic. there are many ways to represent schematic in different tools and in different formats. unless you can clarify your question, there is nothing more to be said.
whatever these terms are, they are not standard. I don't know what YOUR lvs.v file is.
give one example of schematic netlist and normal netlist
I can't. I have no idea what you are calling a schematic netlist and a normal netlist because those terms make no sense.
As a simple example:
1. after place'n'route you have gate-level netlist (.v verilog), which contains std. cells and wires between them).
2. also, you should have spice (transistor-level) netlist (.sp, .cdl or other extensions), which contains transistors and wires for each of you std. cells.
3. you should convert gate-level netlist into spice-like netlist and merge it with std. cell transistor-netlist.
4. the LVS tool extracts transistor netlist from layout (GDSII) and writes it into spice-like netlist .
5. the LVS tool compares your merged tran-level netlist with extracted tran-level netlist.
The extensions of netlist files may vary and depend on LVS tools.
you can make LVS pass using gate-level netlist, no need to do spice vs spice
normal netlist means .v
no it does not. I believe you are referring to a gate-level netlist.
Only in case the hirearchy fully match in schematic and layout. Still, standard signoff (foundry recommended) LVS is transistor-level comparison.
Hierarchy is usually not an issue. And spice vs spice is not needed. You can do verilog vs spice.
In such case - yes, you can. But, tool still converts verilog into spice-like transistor netlist. Transistor-level is the must for signoff LVS.
