baileychic
Advanced Member level 3
Can I use 6A Inductor for LC low pass filter for my 350W Inverter ?
Question: Can I use 6A Inductor for LC low pass filter for my 350W Inverter ?
I am designing a 350W Inverter using 2x PIC18F46K22.
12V 50Ah battery is used and so charging current for battery is 5A.
I want to know two things.
My calculations are like this.
I want to be able to use a 350 W max load and so 20% of 350W is 350 * 0.2 = 70.
350 + 70 = 420W
I am designing Inverter for 420W (because there will be power losses even with good low Rds(on) Mosfets).
As max load is 350W
Irms = 350W/220V = 1.59A
Ipk = 1.59 * sqrt(2) = 2.25A
So, can I use a 6A pk current inductor for my inverter's output ? (LC low pass filter).
Filter calculation is like this.
My SPWM frequency is 16 KHz.
I chose fc = approx 2500 Hz.
I choose L = 0.68 mH 6A and C = 5.6 uF 560V.
fc = 1 / ( 2 * pi * sqrt( L * C))
fc = 1 / (2 * 3.14159265 * sqrt (0.68 * 5.6 * n))
fc = 1 / (3.977 * 10^(-4))
fc = 2579 Hz
It is a pure sinewave inverter.
So, finally my questions again are
1. Can I use 6A Inductor for my purpose ?
2. Will I get clean sinewave output after filter ?
3. If max load current is say 3A then how to calculate DC-DC converter's switching transformer's primary winding current ?
350 + 70 = 420W
As max load is 350W
fc = 2579 Hz
