VHDL Testbench getting (U) in simulation waveform result
12345r
Newbie level 2
I'm trying to simulate 2bit full adder but getting U(undefined) in the waveform result. Can you help me with that please?
1bit full adder
entity full_adder is
    Port ( A : in STD_LOGIC;
       B : in STD_LOGIC;
       Cin : in STD_LOGIC;
       S : out STD_LOGIC;
       Cout : out STD_LOGIC);
  end full_adder;
  architecture Behavioral of full_adder is
  begin
   S<=A xor B xor Cin;
   Cout<=(A and B)or(B and Cin)or(A and Cin);
   end Behavioral;
2bit full adder
 entity full_adder_2bit is
    Port ( A : in STD_LOGIC_VECTOR (1 downto 0);
       B : in STD_LOGIC_VECTOR (1 downto 0);
       Cin : in STD_LOGIC;
       S : out STD_LOGIC_VECTOR (1 downto 0);
end full_adder_2bit;
architecture Behavioral of full_adder_2bit is
Component full_adder
port(A : in STD_LOGIC;
       B : in STD_LOGIC;
       Cin : in STD_LOGIC;
       S : out STD_LOGIC;
end component;
signal C:STD_LOGIC;
begin
Bit_adder0: full_adder port map(A=>A(0),
                    B=>B(0),
                    Cin=>Cin,
                    S=>S(0),
                    Cout=>C);
 Bit_adder1:full_adder port map(A=>A(1),
                           B=>B(1),
                           Cin=>C,
                            S=>S(1),
                            Cout=>Cout);
 end Behavioral;
2bit full adder testbench
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity full_adder_2bit_tb is
--  Port ( );
end full_adder_2bit_tb;
architecture Behavioral of full_adder_2bit_tb is
component full_adder_2bit
port( A : in STD_LOGIC_VECTOR (1 downto 0);
      Cin : in STD_LOGIC;
end component;
constant Period: Time :=10ns;
signal A_tb: STD_LOGIC_VECTOR(1 downto 0):= (others=>'0');
signal B_tb:STD_LOGIC_VECTOR(1 downto 0):= (others => '0');
signal Cin_tb:STD_LOGIC;
signal S_tb: STD_LOGIC_VECTOR(1 downto 0);
signal Cout_tb:STD_LOGIC;
begin
Bit_adder_tb0: full_adder_2bit port map
(A=>A_tb,B=>B_tb,Cin=>Cin_tb,S=>S_tb,Cout=>Cout_tb);
stim_proc: process
variable i,j :integer;
begin
for Cin in 0 to 1 loop
 for i in 0 to 2 loop
  for j in 0 to 2 loop
 A_tb <=STD_LOGIC_VECTOR( to_unsigned(i,2));
B_tb <= STD_LOGIC_VECTOR(to_unsigned(j,2));
    wait for period;
end loop
end loop
end loop
wait;
end process;
end Behavioral;
Cin isn't assigned in the test bench, hence will force u into the adder
I've added the Cin value in the testbench but still getting the same issue with U in the whole waveforms simulation. How can I correct the code to get normal unsigned values in the waveform?
I'm also confused regarding using the STD_LOGIC and unsigned data type? is this related to the issue I'm facing?
The other query is that according to my understanding this code ,
signal Cin_tb:STD_LOGIC:='0';
will assign initial value to cin =0 then what will happen in the loop since I'm assigning the C to Cin again?
library IEEE;
--  Port ( );
      Cin : in STD_LOGIC;
end component;
[B]signal Cin_tb:STD_LOGIC:='0';[/B]
begin
stim_proc: process
begin
[B]for C in 0 to 1 loop
    Cin_tb<=STD_LOGIC(to_unsigned(C,1));[/B]
    wait for period;
end loop
end loop
end loop
wait;
end process;
end Behavioral;
Your loops are pretty useless as you are assigning 2 to both a and b. You are also assigning 1 to c, but this is in a syntax error. A stdlogic is a single bit, while an unsigned is an array of stdlogic that represents an unsigned number. You cannot convert am integer to single bit as it does not represent a number.
