Results 1 to 4 of 4
    Newbie level 2
    Points: 17, Level: 1
    Aug 2017
    17
    VHDL Testbench getting (U) in simulation waveform result
    I'm trying to simulate 2bit full adder but getting U(undefined) in the waveform result. Can you help me with that please?
    1bit full adder
    entity full_adder is
        Port ( A : in STD_LOGIC;
           B : in STD_LOGIC;
           Cin : in STD_LOGIC;
           S : out STD_LOGIC;
           Cout : out STD_LOGIC);
      end full_adder;
      architecture Behavioral of full_adder is
      begin
       S<=A xor B xor Cin;
       Cout<=(A and B)or(B and Cin)or(A and Cin);
       end Behavioral;
    2bit full adder
     entity full_adder_2bit is
        Port ( A : in STD_LOGIC_VECTOR (1 downto 0);
           B : in STD_LOGIC_VECTOR (1 downto 0);
           Cin : in STD_LOGIC;
           S : out STD_LOGIC_VECTOR (1 downto 0);
    end full_adder_2bit;
    architecture Behavioral of full_adder_2bit is
    Component full_adder
    port(A : in STD_LOGIC;
           B : in STD_LOGIC;
           Cin : in STD_LOGIC;
           S : out STD_LOGIC;
    end component;
    signal C:STD_LOGIC;
    begin
    Bit_adder0: full_adder port map(A=>A(0),
                        B=>B(0),
                        Cin=>Cin,
                        S=>S(0),
                        Cout=>C);
     Bit_adder1:full_adder port map(A=>A(1),
                               B=>B(1),
                               Cin=>C,
                                S=>S(1),
                                Cout=>Cout);
     end Behavioral;
    2bit full adder testbench
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.NUMERIC_STD.ALL;
    entity full_adder_2bit_tb is
    --  Port ( );
    end full_adder_2bit_tb;
    architecture Behavioral of full_adder_2bit_tb is
    component full_adder_2bit
    port( A : in STD_LOGIC_VECTOR (1 downto 0);
          Cin : in STD_LOGIC;
    end component;
    constant Period: Time :=10ns;
    signal A_tb: STD_LOGIC_VECTOR(1 downto 0):= (others=>'0');
    signal B_tb:STD_LOGIC_VECTOR(1 downto 0):= (others => '0');
    signal Cin_tb:STD_LOGIC;
    signal S_tb: STD_LOGIC_VECTOR(1 downto 0);
    signal Cout_tb:STD_LOGIC;
    begin
    Bit_adder_tb0: full_adder_2bit port map
    (A=>A_tb,B=>B_tb,Cin=>Cin_tb,S=>S_tb,Cout=>Cout_tb);
    stim_proc: process
    variable i,j :integer;
    begin
    for Cin in 0 to 1 loop
     for i in 0 to 2 loop
      for j in 0 to 2 loop
     A_tb <=STD_LOGIC_VECTOR( to_unsigned(i,2));
    B_tb <= STD_LOGIC_VECTOR(to_unsigned(j,2));
        wait for period;
    end loop
    end loop
    end loop
    wait;
    end process;
    end Behavioral;
    •   Alt27th August 2017, 18:04
      advertising
    Points: 35,007, Level: 45
    Jun 2010
    6,414
    35,007
    45
    Re: VHDL Testbench getting (U) in simulation waveform result
    Cin isn't assigned in the test bench, hence will force u into the adder
    •   Alt27th August 2017, 18:45
      advertising
    Newbie level 2
    Aug 2017
    17
    I've added the Cin value in the testbench but still getting the same issue with U in the whole waveforms simulation. How can I correct the code to get normal unsigned values in the waveform?
    I'm also confused regarding using the STD_LOGIC and unsigned data type? is this related to the issue I'm facing?
    The other query is that according to my understanding this code ,
    signal Cin_tb:STD_LOGIC:='0';
    will assign initial value to cin =0 then what will happen in the loop since I'm assigning the C to Cin again?
    library IEEE;
    --  Port ( );
          Cin : in STD_LOGIC;
    end component;
    begin
    stim_proc: process
    begin
    for C in 0 to 1 loop
        Cin_tb<=STD_LOGIC(to_unsigned(C,1));
        wait for period;
    end loop
    end loop
    end loop
    wait;
    end process;
    end Behavioral;
    •   Alt28th August 2017, 02:57
      advertising
    Jun 2010
    6,414
    35,007
    45
    Your loops are pretty useless as you are assigning 2 to both a and b. You are also assigning 1 to c, but this is in a syntax error. A stdlogic is a single bit, while an unsigned is an array of stdlogic that represents an unsigned number. You cannot convert am integer to single bit as it does not represent a number.
