Magic layout software grid is not showing.
ammar_kurd
Junior Member level 3
Yemen
Hello all,
I am working on my laptop and I need help with Magic layout software, I need to get the grid to appear, even though I used the command "grid on" and pressed "g" on the keyboard I can't see the grid. Do I need to set some settings for the display screen or something?
Thanks in advance.
Hi
Maybe your grid setup is too small or too wide.
Thanks Klaus, after changing the screen resolution from 1366x768 to any other resolution I can see the grid but the screen viewing is really bad, when I revert back to 1366x768 the grid does not disappear and all is good, I am not sure if it is a bug or not though, but now I have this situation where I have to change my resolution then revert back to 1366x768 for optimal viewing to see the grid.
After 'g' is given , type zoom(z/Z) repeatedly to see the grid.
Thanks Srizbf, I have already tried that but it didn't work.
