ahmad2005
- Joined
- Mar 30, 2011
- Messages
- 40
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Location
- Mirpur,Dhaka,Bangladesh
- Activity points
- 1,618
I have tried several ways to implement a timer interrupt in P33FJ12GP202 using mikroC pro for dsPIC. Unfortunately, non of the configurations has been worked. Can someone let me know, where did I make mistake.
1st one: This one was implemented by reading application notes
2nd on: implemented by using MikroC Timer Calculator tool. https://libstock.mikroe.com/projects/view/398/timer-calculator
I'm using protues for simulation.
//void Timer1Int() org IVT_ADDR_T1INTERRUPT { // Timer1 interrupt handler
void Interrupt() {
if(T1IF == 1) {
if (DONE_bit){ // If ADC is not busy
SAMP_bit = 1; // Start new sample
PORTA.b1 ^= 1; // ~ PORTA.b1; // You can put oscilloscope on PORTD
// to measure sampling frequency
T1IF_bit = 0;
void main() {
TRISB = 0;
TRISA.b1=0;
// Interrupts setup
IFS0 = 0; // Clear interrupt flags
IFS1 = 0; // Clear interrupt flags
// IFS2 = 0; // Clear interrupt flags
NSTDIS_bit = 1; // Nested interrupts DISABLED
INTCON2 = 0; // Other interrupt settings
T1IE_bit = 1; // Timer1 and
AD1IE_bit = 1; // ADC interrupts ENABLED
T1IP0_bit = 1; // Timer1 interrupt priority level = 1
//ADIP1_bit = 1; // ADC interrupt priority level = 1
//TON_bit = 1; // Start Timer1, internal clock FCY, prescaler 1:1
TCKPS_1_bit =0;
TCKPS_0_bit = 0;
TGATE_bit = 0;
TSYNC_bit = 0;
TCS_bit = 0;
PR1 = 0x03E8; // Sampling ~= 80 kHz. The value of 250 is calculated for 80MHz clock.
while (1); // Infinite loop,
// wait for interrupts
//Timer1
//Prescaler 1:64; PR1 Preload = 31250; Actual Interrupt Time = 100 ms
//Place/Copy this part in declaration section
void InitTimer1(){
T1CON = 0x8010;
T1IE_bit = 1;
T1IF_bit = 0;
IPC0 = IPC0 | 0x1000;
PR1 = 62500;
TON_bit = 1;
void main() {
TRISB = 0;
TRISA=0;
PORTA=0;
// Interrupts setup
InitTimer1();
void Timer1Interrupt() iv IVT_ADDR_T1INTERRUPT{
T1IF_bit = 0;
//Enter your code here
