+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Newbie level 5
    Points: 96, Level: 1
    Join Date
    Aug 2017
    Posts
    9
    Points
    96
    Level
    High Level employment of the "imply" operator
    Almost all of the 16 possible logic 2-variable operations can be exemplified with some kind of what I will call here as a medium/high-level circuit.
    Example:
    A XOR gate can be presented with half/full-adders.
    ANDs, ORs, NOTs, NANDS, NORs with its several applications (mux, demux, encoders/decoders, etc).
    But I couldnīt find an example for the imply operation A --> B (or A' + B)
    A B A->B
    0 0 1
    0 1 1
    1 0 0
    1 1 1
    Does anybody know any kind of medium-high level example wich uses the imply operator?
    Regards
    •   Alt17th August 2017, 21:55
      advertising
  2. #2
    Advanced Member level 5
    Points: 19,994, Level: 34
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,853
    Points
    19,994
    Level
    34
    Re: High Level employment of the "imply" operator
    I'm not sure I understand your question; it looks like you already have your answer:
    Out=(NOT A) OR B.
    This would be an OR gate with B on one input and a NOT gate on the other input; the input to the NOT is A.
    •   Alt18th August 2017, 00:28
      advertising
  3. #3
    Newbie level 5
    Join Date
    Aug 2017
    Posts
    9
    Points
    96
    Level
    Quote Originally Posted by barry View Post
    Out=(NOT A) OR B.
    Hi berry,
    thank you for your reply.
    Yes, the imply operator produces the same effect as the A' + B.
    What I am looking for is any combinational circuit that regularly employs the "imply as an imply operator".
    An example: we usually prefer to express A XOR B instead of A'B + AB'.
    Regards
    •   Alt18th August 2017, 00:41
      advertising
  4. #4
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,598
    Level
    100
    I don't understand the exact problem. You know how to implement the intended logic operation, as a matter of fact an "imply" operator isn't available in most commonly used logic description languages.
    Seriously, I don't even see it's purpose.
  5. #5
    Points: 5,373, Level: 17
    Join Date
    Apr 2016
    Posts
    1,131
    Points
    5,373
    Level
    17
    Quote Originally Posted by BrownBear1968 View Post
    Hi berry,
    Regards
    I am so lost. Are you talking about expression factoring?
    Really, I am not Sam.
  6. #6
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,853
    Points
    19,994
    Level
    34
    Quote Originally Posted by ThisIsNotSam View Post
    We're all lost. Not a clue what the op is asking.
    •   Alt18th August 2017, 21:34
      advertising
  7. #7
    Advanced Member level 3
    Points: 4,949, Level: 16
    Join Date
    Feb 2015
    Posts
    825
    Points
    4,949
    Level
    16
    I suspect the OP is asking about basic logic circuits that are normally drawn using different types of gates.
    For example, xor is used in the conditional invert, full-adder, and parity. xnor for compare equal. "and" for enable.
    I'm not familiar of any circuit that performs a basic function that uses this operation. There are certainly complex circuits that have this logic.
    I guess CPU pipelines can allow this logic. allow_pipeline_progress = (data_ready implies sink_ready); If data_ready is true and sink_ready is false the pipeline stalls. if data_ready is false the value might not matter.
