CMOS Inverter Simulation using SPICE
ANALA
Member level 1
Once i build the inverter circuit and simulate using SPICE tool, i can plot the I-V characteristic...Is there any possibility to change the built in drain current expression..[for eg :instead of Id= 0.5K(vgs-vth)^2 to Id=0.5K(vgs-vth)^3] ?
You can write whatever expression you want in spice and evaluate it. That's simple but has no merit, as you are not changing the underlying model of the transistor.
Exactly what i want to do..i want the new drain current expression to over rule the underlying model..is it possible to do?
The default MOSFET level 1 model with LAMBDA = 0 refers to the intended simple quadratic equation
Simulation of real discrete and integrated MOSFET transistors uses more complex models. I don't think that any model ends up with the suggested simplified cubic equation, what's its justification?
You can however make a behavioral voltage controlled current source with exactly this equation. Behavioral modeling syntax is different for SPICE variants, refer to reference manuals.
If i m using PSPICE how should i go about arriving at the equation which i have mentioned?i just gave an eg of a cubic expression ...i m just trying to evaluate an arbitrary drain current expression
Here's a PSPICE example. Use a VCCS (Voltage Controlled Current Source), a G element (GVALUE) as in this example, and put your equation in its transfer function.
