T
treez
Our contractor has come up with a device that he says you connect a 16V rail to (16V & 0V), and then it turns that rail into a DALI signalling rail...It gets its own power from the 16V rail itself..
However, he says there is no datasheet for this device.
The device is a Lucy Zodion F6353-0001 “HALO”
By lucyzodion.com
I cannot find a datasheet for this device.
I am wondering how it manages to get powered when it actually takes the rail to zero volts as when sending a low bit of a DALI signal.
We can feed it a 16V rail via a 55mA current limiter so that it doesn’t take down the “feeding” 16V rail.
How does it get power during the times when it takes the 16V rail low?
By lucyzodion.com
