+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 3
    Points: 936, Level: 6
    Join Date
    Feb 2016
    Posts
    152
    Points
    936
    Level
    Suggestion on methodology/ways to test internal logic analyzer softcore modules
    Using http://zipcpu.com/blog/2017/06/08/simple-scope.html , I have rewritten my internal logic analyzer at https://github.com/promach/internal_logic_analyzer
    Could anyone suggest methodology/ways to test my softcore modules ?
    Click image for larger version.
Name:	Screenshot from 2017-08-14 11-58-48.png
    •   Alt14th August 2017, 05:03
      advertising
  2. #2
    Advanced Member level 3
    Points: 6,797, Level: 19
    Achievements:
    7 years registered Created Blog entry
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    983
    Points
    6,797
    Level
    19
    Blog Entries
    Re: Suggestion on methodology/ways to test internal logic analyzer softcore modules
    You may know that Xilinx provides ILA core for free to be used as internal scopes. Is it not possible to use your own scope (in a place where an ILA core has already been used and the results have been recorded) and compare its behavior with ILA?
    .....yes, I do this for fun!
    •   Alt14th August 2017, 10:23
      advertising
  3. #3
    Full Member level 3
    Join Date
    Feb 2016
    Posts
    152
    Points
    936
    Level
    Should I use traditional memory testing algorithms such as March algorithm or Walking 1/0 ?
    •   Alt14th August 2017, 13:45
      advertising
  4. #4
    Achievements:
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    983
    Points
    6,797
    Level
    19
    Blog Entries
    I can't answer that I don't know. My answer was at a very superficial level.
    You have a known-system and you know its behavior(ILA core). You design a system similar to the known-system. So plug out the working system, put in your own-system and observe its behavior. I didn't look into into you RTL nor do I know in-depth how Xilinx ILA core works.
    So I might be wrong in my suggestion.
  5. #5
    Full Member level 3
    Join Date
    Feb 2016
    Posts
    152
    Points
    936
    Level
    When we test the scope within our bench/cpp Verilator testbench, we'll know if our test was "correct" if the counter 1) only ever counts by 1, and 2) if test was "correct" if the counter 1) only ever counts by 1, and 2) if the trigger lands on thte right data sample.
    What does it mean by the above code comments and https://github.com/ZipCPU/wbscope/bl...scope_tb.v#L73 ?
    •   Alt14th August 2017, 16:09
      advertising
  6. #6
    Full Member level 3
    Join Date
    Feb 2016
    Posts
    152
    Points
    936
    Level
    I am stuck at testing my internal scope.
    https://github.com/promach/internal_...read_mem.v#L19
    raddr does not start increment at the right time...
    already checked my read_enable logic, seems correct
Name:	Screenshot from 2017-08-24 16-00-48.png
