Results 1 to 4 of 4
    Advanced Member level 1
    Points: 4,713, Level: 16
    Jul 2005
    492
    4,713
    16
    Capacitance between human body and all 110-V wiring in a 10'x10' room
    Human body picks up 60-Hz noise from main supply 110-v wiring in rooms. It should be from electrostatic mode coupling.
    Is there any article estimated how much parasitic C is between human body and the wirings? Or estimate how much 50-60 Hz voltage noise will human body normally carries in a regular living space?
    Regards,
    Neo
    •   Alt12th August 2017, 19:42
      advertising
    Points: 5,886, Level: 18
    Mar 2002
    UK
    487
    5,886
    18
    Re: Capacitance between human body and all 110-V wiring in a 10'x10' room
    It's about 20 to 100pF depend on the environment (more metal objects around - 100pF)
    •   Alt12th August 2017, 20:43
      advertising
    Jul 2005
    492
    4,713
    16
    Quote Originally Posted by luben111 View Post
    I believe it is the entire C from human to earth, like in HBM model.
    I am more curious about partially to wiring of 110v main supply only?
    •   Alt12th August 2017, 23:11
      advertising
    Points: 46,735, Level: 52
    Apr 2011
    Minneapolis, Minnesota, USA
    11,654
    46,735
    52
    I just did one of my favorite tests with my oscilloscope. Touching my finger to the signal lead only, I see 2V amplitude of 60 cycle hum. (This is in a normal apartment residence with some appliances running.)
    Since the scope has 1 megohm input impedance, it implies 2uA of current traveling through my body. Supposedly I pick this up via capacitance from house wiring. There are the basic raw calculations if you are looking for a Farad value. Probably in the pF range as suggested in post #2.
