need some help about RTL compiler with some weird assign statement
gzantass
Newbie level 3
Hi guys
I was working on RTL compiler with my code. and I got this module.
As you can see there is an 24 bit output Z, and the last 3 bit of Z are assigned to 1'b0;
module mult_unsigned_const_184(A, Z);
  input [15:0] A;
  output [23:0] Z;
  wire [15:0] A;
  wire [23:0] Z;
  wire n_0, n_1, n_2, n_4, n_5, n_6, n_7, n_8;
  wire n_9, n_10, n_11, n_12, n_13, n_14, n_15, n_16;
  wire n_17, n_18, n_19, n_20, n_21, n_22, n_23, n_24;
  wire n_25, n_27, n_28, n_29, n_30, n_31, n_32, n_33;
  wire n_34, n_35, n_36, n_37, n_38, n_39, n_40, n_41;
  wire n_42, n_43, n_45, n_46, n_47, n_48, n_49, n_50;
  wire n_51, n_52, n_53, n_54, n_55, n_56, n_57, n_58;
  wire n_59, n_60, n_61, n_63, n_65, n_67, n_69, n_71;
  wire n_73, n_75, n_77, n_79, n_81, n_83, n_85, n_87;
  wire n_89, n_91;
  assign Z[0] = 1'b0;
  assign Z[1] = 1'b0;
  assign Z[2] = 1'b0;
later, when the top module called this submodule,
here is the code:
  mult_unsigned_const_184 const_mul_158_28(.A ({data_0[15:11], n_1414,
       data_0[9:7], n_1856, data_0[5], n_1451, n_1578, data_0[2:0]}),
       .Z ({n_3927, n_3926, n_3925, n_3924, n_3923, n_3922, n_3921,
       n_3920, n_3919, n_3918, n_3917, n_3916, n_3915, n_3914, n_3913,
       n_3912, n_3911, n_3910, n_3909, n_3908, n_3907, UNCONNECTED14,
       UNCONNECTED15, UNCONNECTED16}));
and you can see the last 3 bits are not connected to net.
So in the netlist, these 3 bits are not doing anything.
How did the RTL compiler synthesis them out, why not just use a 21 bit output instead?
And most important question, how should i fix this problem please?
Thanks
this is pretty standard. it means some logic got optimized out, but rtl compiler leaves this UNCONNECTED nets behind to let you know what it did.
Inspect what is happening to those 3 LSB bits, which kind of logic was connected to them, and why those were optimized out. Dig into your RTL.
it is an multiply to constant module.
I tried to break down the steps.
during the elaborate, those 3 bits are still driven by some logic gates.
and after synthesis they are gone.
Those are not feedthrough or tri-state assign so I could not remove them by remove_assigns .
I guess maybe I should try TIE_LO cells?
Thanks
Thanks
they were removed because they drive nothing. if you put tie_lo cells, they will still drive nothing. the tool is optimizing these bits away because they are not needed.
my problem is that the tool didn't optimizing them away. as you can see from the netlist, they are still there in the port definition. so they will show up in schematic and cause LVS error.
I've no idea how to make the tool to remove them (maybe like redefine the port width?). the only thing I can do now is adding tie_lo cell so I wont receive LVS error.
Can you help me with optimizing this please? I tried remove_assigns related commands but seems not work.
Thanks
Thanks
sorry, this makes no sense. if you want to prevent synthesis from optimizing logic so LVS will pass, you are very lost.
