tiwari.sachin
Full Member level 6
I am using a simple circuit as given below. The output of schmitt trigger (FEED_SWITCH) connects to the microcontroller.
Sometimes the cap C49 fails and i need to replace it. The cap voltage is 16V and its a ceramic.
I tested output at pin 2 and pin 4 of U13 selecting DC Coupling on CRO and the output was as desired.
But the moment i selected AC coupling. I got the output as below.
Is this voltage adding up on DC and damaging capacitor?
Earlier designs i never used SCH Trigger and MCU IO used to damage.
The results on AC coupling mode was same even when i removed C49 and even D19
If this is possible reason for damage then how can i reduce this effect.
