How to get exact 1 ms Timer0 OVF Interrupt for ATMega8A ?
baileychic
Advanced Member level 3
This is my code. I am not getting exact 1 ms interrupt. My OSC is 4 MHz Internal RC Oscillator. Fuses are correct.
void InitTimer0() {
    TCCR0 = 0x02;
    SREG_I_bit = 1;
    TOIE0_bit = 1;
void Timer0Overflow_ISR() org IVT_ADDR_TIMER0_OVF {
    TCNT0 = 0x06;
How exact do you want the 1ms?
Give a tolerance.
--> internal RC isn't very precise
Do you want a one shot 1ms, or continously 1ms?
This tells nothing about what you see.
Is it 1.00001ms or do you see 0.1ms, or do you see 100ms or do you see varying timing?
Fuses are correct.
So why do you hide them as secret?
--> The more valuable informations you give the better is the response.
Klaus
ТССR0 = 3; // prescaler 64
//TCNT0 reload value:
TCNT0 = 4E6/64/1000-1; //interrupt freq. approx. 1008Hz
You want exact 1.000kHz interrupt frequency?
Then use another timer/counrt with ctc mode.
Klaus
Is this correct ?
TclkT1 = 64/fclkI/O = 64/4 MHz = 1.6us
1ms/1.6us = 62.5
= ~ 63
65536 - 63 = 65473 = 0xFFC1
TCNT1H = 0xFF
TCNT1L = 0xC1
Prescalar = 64
TCCR1A = 0x00
TCCR1B = 0x03
void InitTimer1() {
	SREG_I_bit = 1;
	TCCR1A = 0x00;
	TCCR1B = 0x03;
	TCNT1H = 0xFF;
	TCNT1L = 0xC1;
	TOIE1_bit = 1;
void Timer1Overflow_ISR() org IVT_ADDR_TIMER1_OVF {
	TCNT1H = 0xFF;
	TCNT1L = 0xC1;
	PORTB.B1 = ~PORTB.B1;
Now you switched to timer1
* it is a 16 bit timer, now you could use divider of 8 to get exact 1.000ms --> you are loosing accuracy
* now you have ctc available, but you don't use it --> you are loosing precision
Klaus
I don't know about CTC. I was writing code for an existing hardware. If Timer1 COMPA is used then PORTB.B1 was not working. So, I switched to OVF. I tried with Timer0 but didn't get exact 1ms and hence tried with Timer1 OVF.
Before I read the datasheet I didn't know about CTC, too.
But lucky us, they have written the datasheet.
Klaus
