Function generator output amplifier
DonC1
Newbie level 1
I would like to amplify the output from a function generator. The freq range needs to be from DC to around 10k Hz. Signal may be triangle, ramp, sine wave, square wave or whatever. I want to drive motors and other stuff with the amplified output. Need up to 50 volts and 10 amps. Thinking op-amp and transistors or something like that. Any help on pointers on schematic etc would be appreciated.
You better to go ahead with class D power amplifier for high power application see the link below
It is rated 500W audio power actual power (RMS Power) will be less than 500W
What Smijesh said. Use one of those Ebay amplifier boards.
Be aware that a 10 Khz square wave could cause output ringing.
