Anwesa Roy
I want to perform the small signal AC analysis of the circuit. To calculate gm. I need IC ,ie the DC quiescent collector current. But in the differential amplifier stage, the AC input voltages are not connected via capacitors....So while performing DC analysis ,we cannot open circuit the AC voltage sources. Then how we are to find the quiescent collector currents?...Also even if the AC voltage sources are connected via capacitor, then while DC analysis, the base would be floating....!Please help me solve this problem.
