+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Advanced Member level 5
    Points: 12,118, Level: 26
    Join Date
    Aug 2011
    Posts
    2,464
    Points
    12,118
    Level
    26
    Same constant name in 2 different packages
    Hello,
    This is somewhat a followup to this post
    http://www.edaboard.com/showthread.php?t=369737
    Unfortunately, I tried the proposed solution in post #9 and it didn't work.
    So I'll try again
    "some_package_1" contains a constant named : "some_constant"
    library ieee ;
    	use ieee.std_logic_1164.all ;
    	use ieee.numeric_std.all ;
    package body some_package_1 is
    constant some_constant : std_logic := '0' ;
    end package body some_package_1 ;
    "some_package_2" contains a constant with the same name but a different value.
    library ieee ;
    package body some_package_2 is
    constant some_constant : std_logic := '1' ;
    end package body some_package_2 ;
    In my code, I'd like to compare "some_constant" from some_package_1 to "some_constant" from some_package_2.
    library ieee ;
    library work ;
    use work.some_package_1.all ;
    use work.some_package_2.all ;
    signal some_signal : std_logic ;
    begin
    	some_signal <= some_constant(from some_package_1) and some_constant(from some_package_2) ; -- How should I rewrite this line to make it work?
    end architecture ;
  2. #2
    Super Moderator
    Points: 237,321, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,068
    Points
    237,321
    Level
    100
    Re: Same constant name in 2 different packages
    it didn't work
    Means syntax error flagged, wrong item selected,...?
    Did you try the regular syntax for expanded names, e.g. work.some_package_1.some_constant ?
    •   Alt5th August 2017, 13:22
      advertising
  3. #3
    Join Date
    Aug 2011
    Posts
    2,464
    Points
    12,118
    Level
    26
    Yes.
    This is the exact line:
    some_signal <= work.some_package_1.some_constant and work.some_package_2.some_constant ;
    Modelsim error message:
    Unknown resolved name
    •   Alt5th August 2017, 17:00
      advertising
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,068
    Points
    237,321
    Level
    100
    I don't get any errors when compiling a similar example.
    The package definitions in post #1 are incomplete (package body without package declaration).
    •   Alt5th August 2017, 18:50
      advertising
  5. #5
    Join Date
    Aug 2011
    Posts
    2,464
    Points
    12,118
    Level
    26
    OK.
    I changed it - it doesn't work..some_package_2.txtsome_entity.txtsome_package_1.txt.
    Please change the *.txt to *.vhd and compile... does it work ?
  6. #6
    Junior Member level 1
    Points: 369, Level: 4
    Join Date
    Mar 2016
    Posts
    15
    Points
    369
    Level
    This should work: just use full qualified names and do not import "all":
    Quote Originally Posted by shaiko View Post
    library ieee ;
    library work ;
    -- use work.some_package_1.all ;      remove this
    -- use work.some_package_2.all ;      and this
    	some_signal <= work.some_package_1.some_constant and work.some_package_2.some_constant ; -- change here
  7. #7
    Join Date
    Aug 2011
    Posts
    2,464
    Points
    12,118
    Level
    26
    This is my last code:
    library ieee ;
    library work ;
    --use work.some_package_1.all ;
    --use work.some_package_2.all ;
    entity some_entity is
    end entity some_entity ;
    architecture rtl_some_entity of some_entity is
    begin
    end architecture ;
    As suggested these have been commented away
    Compilation fails.
  8. #8
    Join Date
    Mar 2016
    Posts
    15
    Points
    369
    Level
    Compilation fails.
    Post the error message.
  9. #9
    Join Date
    Aug 2011
    Posts
    2,464
    Points
    12,118
    Level
    26
    I found the bug.
    This code compiles now without errors (even with the ".all" in place).
    library ieee ;
    library work ;
    begin
    end architecture ;
    The problem was in the packages.
    I declared the constants in the package body instead of in the package head.
    I.E, I changed this:
    library ieee ;
    package some_package_1 is
    end package some_package_1 ;
    To this:
    Did the same change for "some_package_2" and now it compiles.
    •   Alt5th August 2017, 22:11
      advertising
  10. #10
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,068
    Points
    237,321
    Level
    100
    The constants are not exported because they are not contained in the declaration. A package body isn't needed at all for constant definition. Try this way
    Code VHDL - [expand]
    library ieee ;
  11. #11
    Join Date
    Aug 2011
    Posts
    2,464
    Points
    12,118
    Level
    26
    This is exactly what I wrote in #9
  12. #12
    Points: 35,066, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,423
    Points
    35,066
    Level
    45
    But FvM was pointing out that you kept the package body, which is now empty - this is not required.
    Overall this is a scoping problem, and again, as pointed out, only things in the package declaration are visible externally. Declaring new items in the body are only visible in the body, and dont need a corresponding declaration in package declaration region.
    Another thing that has always been possible in packages is deferred constants. This way you can declare the constant without a value in the package declaration, and then assgn the value in the body. This could allow you to have multiple values for constants by have multiple bodies in different files, and only compiling the one needed in the given project.
    8
    9
    10
    11
    12
    13
    package impl_pkg is
      constant SOME_NUMBER : integer;
    end package;
    --in file 1
    package body impl_pkg is
      constant SOME_NUMBER : integer := 10;
    end package body;
    --file 2
     constant SOME_NUMBER : integer := 88;
    end package body;
    This has become somewhat redundant in VHDL 2008 with the inclusion of package generics (and in VHDL 2017 generics specifically on protected types too :) )
