+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Junior Member level 1
    Points: 116, Level: 1
    Join Date
    Jul 2017
    Posts
    17
    Points
    116
    Level
    xilinx timing analyze using modelsim SE
    Hello
    I'm trying to simulate a simple D Flip Flop in xilinx 14.7.I've wrote the testbench and I set the modelsim as simulator an I did the behavioral simulation without any problem but when I try to simulate the place & route simulation I can't see the result.
    This is my code :
    Code Verilog - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    module dff(in, clk, reset, q);
        input in;
        input clk;
        input reset;
        output reg q;
     always @ (posedge clk or posedge reset)
      begin
       if(reset)
        begin
         q    = 1'b0;
         end
       else
        begin
          q    =  in;
         end
      end
    and this is the testbench :
    module dff_test;
       localparam T=10;
        // Inputs
        reg in;
        reg clk;
        reg reset;
        // Outputs
        wire q;
        // Instantiate the Unit Under Test (UUT)
        dff uut (
            .in(in),
            .clk(clk),
            .reset(reset),
            .q(q)
        //defining clock
        always begin
         clk = 1'b0;
         #(T/2);
         clk = 1'b1;
         #(T/2);
       end
        //defining reset
        initial begin
         reset = 1'b1;
         #(T/2);
         reset = 1'b0;
         #(T/2);
        end
        //input vectors
        initial begin
         in = 1'b0;
         #(T);
         #(T/10);
         in = 1'b1;
         #(T);
         in = 1'b0;
         #(T);
        end
    endmodule
    this is behavioral result:
    Click image for larger version.
    this is timing result:
    actually I should say ISE 14.7
    •   Alt3rd August 2017, 17:53
      advertising
  2. #2
    Super Moderator
    Points: 27,821, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,355
    Points
    27,821
    Level
    40
    Re: xilinx timing analyze using modelsim SE
    It looks like GSR is a weak 1 after 0 ns. It is initialized to 1 then 0 after 100 ns in the glbl.v, so you started applying your simulation stimulus too soon as it's still in reset.
    The reason the behavioral result works is due to being a behavioral description that does not require glbl.v so is not in reset when the D input has a 1 on it.
    You should also fix your reset it's way too short (it's not even a full clock cycle wide)
    1 members found this post helpful.
