cplia
Member level 2
Dear All,
I am trying to calculate the E-field (in dBuV/m) generated by an antenna, given the input signal on the antenna's terminals and the antenna AF supplied by the manufacturer, all at a specific frequency.
Example: Signal generator feeds the antenna with Vt=100dBuV at 40MHz (ignore cable losses for simplicity). The AF at 40MHz is 12dB/m.
So, the E-field generated by the antenna is: E = AF + Vt = 12dB/m + 100dBuV = 112 dBuV/m. Right?
I have been using AF to assess the E-field incident on the antenna, and I am wondering whether the AF can also be used to estimate the E-field generated from a transmit antenna.
Thanks.
Kostas
Thanks.
Kostas
