yishaika
Newbie
I need an All-pass first order filter that is opposite (complementary?) to the usual implementation. I need it to have a phase shift of -180 degrees when approaching DC, -90 degrees at w0, and 0 degrees going to high frequencies.
All normal implementation I found have decreasing phase shift (from +180 to 0 degrees, or from 0 degrees to -180 degrees). This is required to compensate for another filter operating on a wide band (3KHz to 40KHz) signal. Is such an analog filter possible?
