Results 1 to 5 of 5
    Newbie level 5
    Points: 89, Level: 1
    Jul 2017
    9
    89
    Amp ADC interfacing using VHDL for Spartan-3A
    Hello!
    I am relatively new to VHDL. I have tried some smaller tasks and have been successful. I have been working interfacing amp and ADC of a Spartan-3A starter kit for my project. I have been working on it for months and haven't been able to make any progress. I got a reference code from http://www.edaboard.com/thread213091.html
    But I am not able to understand some things:
    Why are we checking bit 12? --- if(amplitude1_buffer(12) = '1') then
    What does this command mean? -- SPI_MOSI <= gain2(3 - cnt);
    Why does mclk do? And what is the trigger used for?
    Also, if anyone has a UCF file and if you've written a code for this, can you please please please send it to me?
    I really need a reference.
    I am really looking forward to your help.
    Thanks and regards,
    NJ176
    •   Alt31st July 2017, 09:44
      advertising
    Points: 53,016, Level: 56
    Most Frequent Poster
    Apr 2014
    10,674
    53,016
    56
    Re: Amp ADC interfacing using VHDL for Spartan-3A
    Hi
    I don't want to read the whole foreign thread...
    I assume bit 12 is the MSN and therefore the sign bit..
    According trigger and MCLK: it is urgent for you to read the ADC datasheet.
    •   Alt31st July 2017, 10:26
      advertising
    Points: 27,821, Level: 40
    ads-ee's Avatar
    Sep 2013
    USA
    6,355
    27,821
    40
    Quote Originally Posted by NJ176 View Post
    Because the code writer is clueless about how to write a proper shift register.
    As cnt increments 0, 1, 2, 3 you select gain2(x) where x is 3, 2, 1, 0. Later it uses gain2(7-cnt) for 7, 6, 5, 4.
    Shows the coder doesn't know what a shift register is.
    Looks like the ADC must have a SPI interface. I'd go find a better SPI implementation than this code.
    •   Alt31st July 2017, 17:24
      advertising
    Newbie level 5
    Jul 2017
    9
    89
    Thank you so much for all your replies, especially ads-ee.
    Could you please help me figure what does mclk do? Because I have checked the data sheet and I am still not able to figure it out. The data sheet only mentions the use of one clock. And mclk is an input, so where would this input come from?
    Thank you so much for your replies in advance.
    ads-ee's Avatar
    Sep 2013
    USA
    6,355
    27,821
    40
    mclk is a higher frequency clock used to generate the divided down timing of the SPI. As I've stated before you should probably find a better representation of SPI code as this version was likely written by someone with a software background as it uses more of a software approach to the design. Anyone familiar with a hardware implementation of SPI would use shift registers and would avoid using variables for counters as that results in the addition with 1 occurring after the FFs.
    I'm pretty sure this design synthesizes to something quite a bit bigger than a more optimal implementation, specifically due to the multiplexing done to replicate the much simpler shifting.
