Results 1 to 2 of 2
    Member level 3
    Points: 329, Level: 3
    Feb 2017
    56
    329
    "ls" command not working
    Hello all,
    I messed up something while installing a rpm package in redhat 6.5. After that "ls" command not working it shows as
    [User@home ~]$ ls
    ls: /lib64/libacl.so.1: version `ACL_1.2' not found (required by ls)
    how to fix this ? please help
    •   Alt15th July 2017, 10:04
      advertising
    Points: 11,220, Level: 25
    Nov 2012
    2,103
    11,220
    25
    Re: "ls" command not working
    I presume you are using yum? please reinstall build-essentials.
    Do not delete files in the system directory by hand. Use yum to remove packages.
