Thevenise circuit problem
cartman007
Member level 2
Hi everyone
I have to thevenise this circuit. I have done the problem but would like your input since I have not done this in a very long time.
Finding Rth
(1/20 + 1/8 ) ^-1 = 7.714ohm.
( 1/7.714 + 1/5 )^-1 = 3.03ohm
3.03 + 2 = 5ohm
soo Rth = 5ohm
Find Vth or voltage over 5ohm.
Rtotal = 20 + (1/8 + 1/(5+2))^-1 = 23.73ohm
Itotal = 20 / 23.73 = 0.85579 Amp.
V-20ohm = IR = 0.85579 * 20 = 17.115V
V-8ohm = 20-17.115 = 3.73V
So V-5ohm = 3.144( 5 / 2+5 ) = 2.2457V
Am I correct in assuming that the voltage over 5-ohm is what they are looking for in the question ?
Could this be a legitimate Rth and Vth answer?
Thanks
I would start at the other end.
5 ohms (R) + 2 ohms = 7 ohms
The 7 ohms is now paralleled with 5 Ohms
(7*5)/(7+5) = 35/12=2.9166666
now we have a 2 ohm in series, so
2+2.9166666=4.91666666 ohms
now we have 8 ohms in parallel with that
(8*4.91666666)/(8+4.916666)=39.3333333/12.916666666= 3.04516129 ohms
finally, you have a 20 ohm in series
=23.045... ohms
Your method and results are correct (unless the rounding error)
The exact values are: Rth = 448/89 ≈ 5.033707865 , Vth = 200/89 ≈ 2.247191011
=23.045... ohms
I didn't get a chance to finish
20 V / 23.045.. ohms = 867.861 ma
through the 20 ohm gives an IR drop of 17.357..Volts
leaving 2.642..Volts agross the 8 ohm
2.642../8 ohms = 330.347 ma into the 8 ohm.
867.861ma - 330.347ma = 537.513 ma through the 2 ohm.
that gives us an IR drop of 2ohms * 537.513 ma = 1.075.. volts...That is one answer.
2.624..V - 1.075..V = 1.5677.. volts across the 5 ohm.
1.5677 / 5 = 313.5498.. ma
537.513 ma - 313.5498 ma = 223.964 ma
That is the other answer
Another approach would be to start with the 20 V and the 20 and 8 ohm resister
20 ohm parallel 8 ohm
(8*20)/(8+20)= 5.714... ohms
and a voltage divider value
20V *8 ohm / (8 ohms + 20 ohms) = 5.714 volts
So we have a 5.71 voltage source with a internal impedance of 5.714.. ohms
we tie a 2 ohm in series
so now we have a 5.71 volt source with a 7.714... ohm impedance.
next we take the 5 ohm and we have another voltage divider
5.71..V *5 ohms/(5 ohms + 7.714..ohms)= 2.247...V
and a impedance of (5*7.714)/(5+7.714) = 3.0337... ohms
Now we have a 7 ohm load on that (2 ohms + R) R=5 ohms
So for I, we have 2.247V / 10.0337 ohms (load + impedance) = 223.964... ma
That is one of the answers
now we take 223.964 ma * 7 ohms to get 1.5677... volts across 5 ohms
So the current in the 5 ohms is 1.5677../ 5 = 313.549...ma
Add that to the current in the 2 and 5 ohms
313.549 ma + 223.964 ma = 537.514.. ma
So the IR drop of the 2 ohm is 537.514 ma * 2 ohms = 1.075... volts
the answer to the second question V
From post#2:
It should be "8 Ohms" instead of "5 Ohms"
Klaus
From post#2:
Klaus
No, I started on the far right
R=5 ohms and there is a 2 ohm resistor in series with that.
You are correct.
I had the third pictire of post#1 in mind.
Sorry.
Klaus
You are correct.
Sorry.
Klaus
Hey, I'm just happy that I got the same answer, doing it from two directions. Usually , you make at least one mistake.
