Results 1 to 13 of 13
    Newbie level 5
    Points: 61, Level: 1
    Jul 2017
    8
    61
    Programmable Priority Encoder
    Can someone help me in designing a programmable priority encoder using verilog . A programmable priority encoder is a device where in addition to the the normal i/p and o/p's of a simple priority encoder there is one more input to decide which bit should have highest priority. Eg. for 4 : 2 programmable priority encoder..there would be 2 select input to decide the priority say [1:0]S.
    If S=00; I0 has highest priority..and the priority order will be I0>I3>I2>I1
    If S=01; I1 has highest priority..and the priority order will be I1>I0>I3>I2
    If S=10; I2 has highest priority..and the priority order will be I2>I1>I0>I3
    If S=11; I3 has highest priority..and the priority order will be I3>I2>I1>I0
    ..The solution is desired to be generic like the logic should remain same for 8:3 and 16:4 priority encoders as well...
    Any suggestions would be very helpful...Please help ASAP!!
    Points: 34,548, Level: 45
    Jun 2010
    6,332
    34,548
    45
    Re: Programmable Priority Encoder
    So what have you done so far, and what are you having problems with?
    •   Alt13th July 2017, 18:49
      advertising
    Newbie level 5
    Jul 2017
    8
    61
    Well..my first approach was that to make a 8:3 programmable priority encoder I made eight regular priority encoders and one 8:1 mux . Each priority encoder has a fixed request order, and the multiplexer passes the desired code to the output. But its is not very efficient . I want a logic which is more efficient but nothing is striking my head.
    Newbie level 5
    Jul 2017
    8
    61
    Yeah but I wish to design such a logic in which when a 4:2 programmable priority encoder is converted to a 8:3 programmable priority encoder no major changes have to be made. If you seem to have any idea on how to do it please help me out.
    Points: 234,633, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    40,542
    234,633
    100
    But its is not very efficient.
    I doubt that it matters. You write a behavioral description of the logic function and the synthesis tool tries to minimize the logic.
    I don't see a problem to write a parameterizable generic encoder description which works for N outputs and select inputs respectively 2^N request inputs.
    Btw, the encoder should also have a specific output to "no request set", so you either need to reduce the number of request inputs to 2^N - 1, or use an additional encoder output.
    Newbie level 5
    Jul 2017
    8
    61
    Are you really not getting what I wanna say..See I got a thing here...If we add a left rotator followed by a priority arbiter and then a right rotator followed by an encoder...This would act like a priority encoder..
    •   Alt16th July 2017, 18:31
      advertising
  7. #7
    Jun 2010
    6,332
    34,548
    45
    Its not clear what you really want help with, or what the problem really is.
    Have you written any code? have you compared different implementations?
  8. #8
    Advanced Member level 3
    Points: 4,492, Level: 15
    Feb 2015
    746
    4,492
    15
    A for-loop version probably works fine.
    if not, you can convert it into a rotate + priority encoder + adder, at least for the 2^N inputs case.
    There are a few other implementations possible. For example, you can create constants for 10101010, 11001100, 11110000 etc... based on elaboration time constants. Then you can use the "(-x) and (x)" trick to get a one-hot value. each bit of the encoder is then the or-reduction of "constant(n) and one_hot". That sounds interesting, but I'm not sure if it is actually better. The use of the addition should force the tools to use a different implementation method though.
    But I'd start by comparing the for-loop version to a more verbose fixed sized version. It doesn't take much time and allows you to determine if the for-loop approach happens to map better to a LUT based implementation.
  9. #9
    Newbie level 5
    Jul 2017
    8
    61
    Please elaborate the one hot method ...Are you talking about masking the input requests or something else..please elaborate it..
  10. #10
    Feb 2015
    746
    4,492
    15
    The expression "(-x) and (x)" will result in either 0 (if the input is 0), or a vector in which the rightmost '1' is the only bit set. This is easy to show by doing each step of the computation.
    If the input has only a single 1, the priority encoder logic is much simpler and can be implemented by doing and-or logic with "10101010", "11001100", and "11110000" (for 8 inputs). This is the vector where the value is '1' for index 0, 1, and 2 respectively.
    This method is of interest only as the coding style is different, and it implements the inductive logic using a carry chain.
  11. #11
    Newbie level 5
    Jul 2017
    8
    61
    Can you describe an hardware based design for a programmable priority encoder ..like through rotators encoders etc...
  12. #12
    Newbie level 5
    Jul 2017
    8
    61
    [merged] Programmable Priority Encoder
    Help regarding structural modelling of a programmable priority encoder(ppe)...Where different blocks can be coded in behavioral model but overall ppe must be modeled in structural manner...
    •   Alt29th August 2017, 15:41
      advertising
  13. #13
    Newbie level 5
    Jul 2017
    8
    61
    Quote Originally Posted by vGoodtimes View Post
    Can you please elaborate the rotate + priority encoder+ adder method...Please explain it ...How it works?
