ADC and DAC Types and applications with SNR INFORMATIONS
Bjtpower
Full Member level 5
Hello friends
I would like to understand the Types of ADC and DAC with the SNR Considerations
As well i want a weblink or application note of genuine manufacturers..
I googled it but not getting exact informations
Regards
Marx
EVERY manufacturer will give you SNR values for their converters. Look at TI, Analog Devices, Linear Technology etc.
Hi am working on the ADC
ADC is having a 10 bit.
What is maximum sampling frequency can i apply.
I want to measure a analog voltage for the controller.
On what parameter we can decide the sampling time.
i am using 16 bit micro controller for my applications
https://ww1.microchip.com/downloads/en/DeviceDoc/39897c.pdf
Marx
Wow. Why don't you just read the data sheet? Right there on the third page it says : 10-bit ADC 500ksps.
I recommend to do the development with the correct order of steps:
* first decide your analog signal specifications according your application.
* then decide the ADC specifications
* then select the ADC.
Klaus
Klaus
OP has apparently already picked his ADC-it's built into his uP.
