Differential Current Acquisition
ipq
Newbie level 3
Hello,
I'm working on a project where I must measure the AC current of a low consumption lamp (~120mA) and send it via RF using a MCU. The point is:
I have found different methods to measure AC current and there's one of them which I do not understand. It is the method used by the kill-a-watt units:
https://reindeerflotilla.files.wordpress.com/2011/08/kill-a-watt.png
Could anyone explain how it is working? Please shed light on the matter:)
Thank you in advance! :thumbsup:
P.S: Before this method I tried the well-known ACS723 but the values obtained were wrong compared to an ammeter:(
What do you mean with "wrong values"? Do you think they are off specification?
Maybe they are not useful for your low current...
your circuit:
* there is a shunt. Voltage drop is proportional to current.
* and there is a difference amplifier. It amplifies the voltage across the shunt and adds an offset voltage. That´s all.
But maybe you should start to specify your needs.
Klaus
The offset of the ACS723 is 20mV with a sensitivity of 400mV/A giving an offset current error of 50mA.
So it's not surprising that it was not accurate for your 120mA measurement.
You need a sensor with more sensitivity.
Thank you for your support:)
The fact is that I have to figure out a way to measure low currents for AC and I do not find any solution except the allegro series...
Any idea? Could you please support me on how to design such a kind of circuit with a shunt?
Thank you in advance.
If the lamp is powered from the AC mains you need isolation.
For that you could use a current transformer.
The current shunt is placed on the isolated output of the transformer and one end can be grounded, so it doesn't need differential amplification.
A Google of "small current transformer" will give you many hits.
Could you please describe how would you measure with the current transformer + shunt without differential amplification? I've never tried to measure negative voltages with the ADC of a MCU so I do not know what would happen....
Assuming in that case the ADC returns 0 (Vref-) I guess the solution could be monitor for instance...500 readings and then calculate the average and check it with the current transformer datasheet to calculate the current? What do you think...Am I right?
Again, thank you for your valuable support.
Two ways to avoid negative voltage from a current transformer output (which is generated across a burden resistor):
1) Rectify the AC into DC with an op amp precision rectifier circuit.
Measure the DC voltage with the ADC
2) AC couple the voltage through a capacitor with a DC offset at the output equal to 1/2 the ADC input range.
Measure the offset AC voltage with the ADC.
