Results 1 to 8 of 8
    Points: 12,223, Level: 26
    Aug 2011
    2,484
    12,223
    26
    What FPGA logic do constants consume
    Suppose I have a large set of ~6000 vectors ( 16 bits each ) which I use as coefficients in my design.
    There's no address decoding (each set is connected to a specific logic block) and all sets are constant during compile time.
    Will these be implemented as simple wires to VCC / GND or there's a chance that the tool will use LUTs / Registers / RAM for some reason ?
    •   Alt11th July 2017, 22:20
      advertising
    Points: 35,441, Level: 45
    Jun 2010
    6,486
    35,441
    45
    Re: What FPGA logic do constants consume
    They just get connected to VCC/GND
    •   Alt11th July 2017, 22:22
      advertising
    Points: 239,611, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,515
    239,611
    100
    If it's appropriate to store the constants in ROM (initialized RAM), you can do that. The tools won't do that "for some reason" rather than your decision.
    •   Alt11th July 2017, 22:30
      advertising
    Aug 2011
    2,484
    12,223
    26
    I don't want to do that.
    I need all values to be accessible simultaneously and (obviously) would prefer it consumes no resources other then routing to VCC / GND.
    Again,
    I have a large array of N vectors and N circuits.
    Each vector is connected to a different circuit.
    The vectors are all constant during compile time.
    Intuitively, I see no reason why these constant vectors shall be implemented by something other than simple wires to either VCC or GND.
    And this is exactly what I want...but I'm not 100% sure.
    Do you agree that that's what would happen ?
    Jun 2010
    6,486
    35,441
    45
    Why not compile the design, and take a look?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    41,515
    239,611
    100
    Why did you ask about RAM then?
    You'll surely get GND/VCC wires in RTL netlist. During synthesis, all possible logic minimizations will be made, pulling the constants into the logic terms. (Unless the logic blocks are locked).
  7. #7
    Points: 5,380, Level: 17
    Apr 2016
    1,131
    5,380
    17
    Quote Originally Posted by TrickyDicky View Post
    Not really, it is more complicated than that. You don't want to have any logic lumped to the ground/vdd wires as they would bounce a lot. You'd typically provide a constant that comes from a special gate called tiecell. There are cells for tie high and tie low. The FPGA vendor might hide that from you, but internally that is how it works.
    Really, I am not Sam.
    •   Alt12th July 2017, 15:04
      advertising
  8. #8
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Sep 2013
    USA
    6,442
    28,167
    40
    Quote Originally Posted by ThisIsNotSam View Post
    Exactly this....
    Shown implemented in Vivado like this:
